1 - 4 of 4 Posts
I need some help with a grom I bought. It’s a 2018 and the guy I bought it from hit a pole and broke the cluster. After replacing the cluster the running lights and turn signals don’t work at all and the horn is always on with the wire connected. He said after the cluster was swapped that it needs to be taken to Honda and have the ecu reprogrammed. I called Honda and they seemed lost by that. So is there something else I should be looking for? Even with the switches unplugged the horn still goes off l if that helps any
Horn could be a shorted wire, could have gotten pinched in the wreck.
Would my best bet for the horn to just take all the plastics off and chase wires back the the fuse box? All the wires under the head light and by the forks appear to be fine
Might start by double checking his wiring job, possible he hooked something up wrong when reassembling.
1 - 4 of 4 Posts
