1 - 1 of 1 Posts
I've got a 2018 Grom that I just replaced the control switch (Signal/Headlight side) with a Tusk Switch
https://www.amazon.com/Tusk-Compact-Control-Switch/dp/B0039ZMOCA
Got everything wired up and it works well!
The headlight switch is a 3 position 3 wire (Off/Low/High). Low beam and high beam positions work but but when I switch the switch to off, the high beams come on...
Was wondering if someone could look over the wiring diagrams and point me in the right direction to making this feature work properly, or if it can be done.
Thanks!
Below is the Tusk wiring, the grom wiring, and the setup I went with
Full grom wiring diagram below
https://static1.squarespace.com/static/5a2ff674d7bdcea4a5e6feed/t/5ce6a3c18165f593ae6d3237/1558619074285/2017+wiring+diagram.pdf
1 - 1 of 1 Posts
