41 - 53 of 53 Posts
I have a White 2017 led headlight with everything needed to fit on your 13-16 Grom ready to go. $325 shipped in the U.S. Comes with everything needed, just bolt it on and plug in your harness and your done. "AC/DC" conversion is needed but can be completed very easily with our included kit. Get it in time for Christmas!!
What all is included in the $325 price? Main thing I'm curious about is what kind of bulb does it come with?
Any info is greatly appreciated.
Discussion Starter #44
Comes with all OEM honda parts to switch the headlight to the 17 and the wiring harness. Only part needed is an ac/dc conversion which must be installed prior to install.
Discussion Starter #50
That is for a delay till your headlight turns on. Typically for Someone that installs an led bulb.
The only way the high beam light can be turned on is to send in your cluster for us to fix it. Once returned your high beam will light up as normal.
$20 for the high beam fix.
Honda Grom Cluster led's
What exactly is this one for?
Grom AC/DC conversion and Headlight Delay Relay "LED/Filament bulbs only"
And will the high beam light function like factory with this kit? I want everything to be as OEM as possible!
Sent from my iPhone using Tapatalk Pro
41 - 53 of 53 Posts
