2017 New Grom
2017 New Grom
This is a discussion on 2017 New Grom within the Introductions forums, part of the Honda Grom News category; Bought a 2017 new Grom from the dealer in SJ, CA. I have had it 5 weeks and 500 miles. I really like it. Since ...
Results 1 to 6 of 6
  • 1 Post By VC2017
Thread: 2017 New Grom
    32286
    2017 New Grom
    Bought a 2017 new Grom from the dealer in SJ, CA. I have had it 5 weeks and 500 miles. I really like it. Since I am on a budget I appreciate the MPG factor too. Only problem I have had so far was adjusting chain. I didn't have a stand and could not get it right after four tries. Took it to the dealer and they did it for 40 bucks. I am thinking about OTB adjusters and getting a stand. As of right now I am a little gun shy to attempt it again. Thanks.
    Cheburashka likes this.
    is pew pew pew
    Cheburashka's Avatar
    6025
    Aug 2015
    Los Gatos, CA
    504
    Welcome!
    How did you manage to find a new 2017... That's awesome.
    Lots of Groms in the South Bay.
    The chains on these bikes that come stock are pretty stretchy. Honestly I'd invest in a better o-ring chain so that you don't have to adjust it all the time.
    Sent from my PH-1 using Tapatalk
    32286
    I think someone bought it and a Talon or something then brought both back with no miles on them. So the dealer gave me a choice of a new 2019 with a warranty for about 1000 dollars more or the one I bought with no warranty. I bought the 2017 with no warranty or ABS.
    I will buy a chain, but I am also leaning to buying those adjusters as well with spools for a rack, and a torque wrench. You may be right though, it might be more economical to buy the chain first, since adjuster, rack and torque wrench are more combined than a new chain even if I had someone install it.
    zroger73's Avatar
    31978
    Texas
    84
    I've got just under 1,100 miles on my 2019 and haven't needed to adjust the chain. It's still quiet, smooth, and within specification. I ride "gently and never in dirt or rain. Every 300 miles, I reach over the bike and pick up the rear so I can spin the wheel and coat the chain with Maxima chain wax.
    12578
    Oct 2016
    salinas
    15900
    24
    Quote Originally Posted by VC2017 View Post
    stock adjusters work perfectly. . just make sure to adjust eachside equally using the guide lines on adjuster. with normal wear n tear your chain adjustment should only need a half of turn to 1 full turn on adjustment nuts. also i pull on chain tightly taking all slack out while impacting axle nut back on keeping it from going out of wack. lube your chain regularly (every few hundred mi). clean and lube(evry thousand mi).
    an o-ring chain is going to be the better choice for overall performance/ maintenance. stock chain is strechy and can feel every kink and loose spots.
    is zipzip
    mygrom's Avatar
    27018
    Feb 2018
    2.1.2.3
    216
    Welcome bud
    ★ Signature: License Plate Flipper
