Introduction's are in order
This is a discussion on Introduction's are in order within the Introductions forums, part of the Honda Grom News category; What's up fellow Grom riders. Im purchasing a 2014 that has been set up to race with WERA and already has a few go fast ...
Results 1 to 5 of 5
Thread: Introduction's are in order
    31220
    Dallas NC
    What's up fellow Grom riders. Im purchasing a 2014 that has been set up to race with WERA and already has a few go fast parts installed. Ohlins suspension front and rear and some other good parts. What should I look at doing next without breaking the bank and still run in a stock type class with this little bike?
    Im Eric and Im 50 years old but love motorcycles and racing them.
    7,840
    Check wheel bearing to make sure your wheels are turning freely, check your chain to make sure it is still usable for racing. Check your engine compression and document the PSI so you'll have a baseline on what the engine health is like. Check your brake pads to make sure it is ok and flush out the old brake fluid and install new fluid. Check and clean your air filter and check and see if your spark plug color is with in reason for a healthy engine.
    Good Luck and Ride it like you stole it.
    is zipzip
    mygrom's Avatar
    27018
    Feb 2018
    2.1.2.3
    181
    welcome welcome!
    ★ Signature: Remote Controlled License Plate Hide Gadget by: TryDeal.com
    is enjoying the riding conditions
    GromMuleCa's Avatar
    29624
    Aug 2018
    North Bay Area, Ca
    1463
    170
    Welcome-i concur w/Cisco, and also check your tires. Have fun ridin!
    2018 Grom White, Yoshimura pipe, Kitaco clutch cover kit, Takegawa Super oil pump, Kitaco clutch springs, HR billet clutch plate, Vagabond rack w/fender eliminator, K&N filter, Pro-taper Mini Hon bar, OPmid 2 temp/volt meter, PV3 flash tool, Koso TT mirrors, OTB Gen 2 billet chain adjuster w/spools
    Manimal's Avatar
    5180
    Apr 2015
    Bay Area, CA
    505
    Welcome! Fellow racer here too - NorCal area.
    Being it is already set-up for racing, probably is good to go as is.
    Change oil with good race oil (if needed), check brake pads, check / adjust chain (or replace), and replace tires, if needed.
    Most importantly, find out what the allowable basic mods are for the class(es) you plan to participate within, and compare to what is currently on your bike, then go from there.
    Other than what is already on the bike, upgrade only the stuff that you feel needs to be changed, or fixed, and or comply within the class rules. Otherwise, race / track as is. No reason spend additional money if you don't really need to. Use that money to fund your track day(s) and race class(es), and or self protection (gear).
    2014 Grom (Red)
  1. Replies: 15
    Last Post: 09-23-2013, 09:44 PM
  2. Replies: 5
    Last Post: 09-07-2013, 06:21 PM
  3. Onyx Racing Introduction
    By Onyx Racing in forum Introductions
    Last Post: 06-11-2013, 04:40 PM
