Koso mini3 afr gauge - Page 2
This is a discussion on Koso mini3 afr gauge within the Grom Talk forums, part of the Honda Grom Forums category; Good to know. Now I wonder the wideband model could it be hooked up with a PCV/WB2. If so, it would fit my needs. Probably ...
Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 46
Like Tree2Likes
Thread: Koso mini3 afr gauge
    D. Flynn's Avatar
    5743
    Nashville, TN
    79
    Good to know. Now I wonder the wideband model could it be hooked up with a PCV/WB2. If so, it would fit my needs. Probably overkill with the few modifications I have, as I will stay at stock bore. Just after the piece of mind you get from what the AFR is while you are WOT on the back highways.
    Dyron
    5498
    May 2015
    42
    Where exactly does it plug into?
    GlockPointer's Avatar
    3606
    352
    [QUOTE=whbwrestling;134239]Where exactly does it plug into?
    It plugs in between the o2 sensor and the harness
    5498
    May 2015
    42
    Where can i find that on the bike do i need to take the plastics off?
    is pew pew pew
    Cheburashka's Avatar
    6025
    Aug 2015
    Los Gatos, CA
    476
    The connector is on the bottom right of the motor. It's the one with the brass nut.
    3606
    352
    Also need to take off the headlight to access the power and ground locations. That's all there is.
    is buying a lot of plastic parts!
    6556
    Nov 2015
    Nashville, TN
    110
    332
    Just installed one, but I think I messed it up. Damn thing always reads "15.7", with very little variation. I even started adjusting the EJK up and down which noticeably and adversely affected the idle speed, but yet the reading never changed much.
    I think since the EJK taps into the O2 sensor, and so does this gauge, I may have the multitude of taps arranged poorly. Dammit. Got too dark outside to screw with it. I'll have to look at it again in the morning.
    3606
    352
    Mine is nothing but variation, even at idle it jumps from too rich to 16.9 to 12.4 to 14.7 on and on. I'm going to install the innovate and run them side by side to see what's up. Either the imap sucks or the koso sucks.
    6556
    Nov 2015
    Nashville, TN
    110
    332
    Now that it's daylight, I went and checked the wiring again. Appears to function, but I'm not convinced it's working right. Mixture shows 17.0 at idle. So I added so much fuel through the EJK that the engine started to stumble. Meter still showed 16.9. Gonna ride with it today and see what it says. Bought it through Amazon, so it may be going back.
    is suffering from grom withdrawal
    symptoms
    3544
    Mississauga, Canada
    286
    My Koso 3 mini AFR gauge at closed loop would hover at 14.7. At open loop and full throttle it's locked at 13.1. Stage 1 mods btw.
  1. Replies: 24
    Last Post: 07-22-2016, 09:47 AM
  2. AFR monitoring with Koso mini3 ?
    By LandCruiser in forum Grom Talk
    Last Post: 07-27-2015, 05:26 AM
  3. Koso cyl temp gauge w' RPM mount
    By Fox85 in forum Grom Performance
    Last Post: 05-16-2015, 03:58 AM
  4. New gauge cluster available from Koso!
    By Fun Size in forum Grom Gear and Accessories
    Last Post: 04-28-2015, 10:20 PM
  5. LCD-200 $250 vs DJ AF Gauge $65
    By Shoebacca78 in forum Grom Talk
    Last Post: 07-23-2014, 08:44 AM
honda grom afr gauge
how did you mount your gagues honda grom
koso afr meter
mini 3 air fuel ratio for honda grom
mini afr gauge
