Those looking for sprockets.... READ THIS!! - Page 2
This is a discussion on Those looking for sprockets.... READ THIS!! within the Grom Talk forums, part of the Honda Grom Forums category; So a stock xr50 or crf50, as they are the same, rear sprocket will fit the grom on the rear? I think a stock 50 ...
Results 11 to 16 of 16
Like Tree2Likes
Thread: Those looking for sprockets.... READ THIS!!
    12690
    Nov 2016
    Cc Texas
    5k\500
    49
    I think a stock 50 rear is 37 also so that'll be almost like 1 down in the front
    2,353
    ^ cross reference part numbers on JT's site for the xr50 and crf50. More than likely yes they are exactly the same.
    sort of. the 50 sprocket has a countersunk hole.
    however this is correct:
    JT Sprockets: Catalogue
    is Never thought stock bore could
    be so good
    estallings15's Avatar
    7251
    10,500
    1,542
    I have that sprocket. It's super heavy
    Takegawa 12.5:1 Piston
    Ported Head w/ TB valves
    2" Intake w/UNI filter
    DanMoto conical exhaust (no kidding)
    2,353
    correct, as denoted in the first post, the CRF50 / XR50 rear sprockets (crossed referenced and those two models are the same) have different holes, but dont pose an issue. Had mine on for 1200 miles without problem.
    12690
    Nov 2016
    Cc Texas
    5k\500
    49
    I put the xr50 sprocket on and torqued the nuts down.
    I put a marker on the nut & sprocket incase they back off I can see it instantly.
    The stock nuts with the xr50 sprocket worked perfect together even with the bevel in the sprocket.
    it moved the rear wheel all the way forward, even better for wheelies.
    rode for 20 miles with wheelies, drag raced a z125 and top end on the freeway with no issues & bolts still in place.
    we used an app on the phone for max mph, it said I did 69mph on the app, bike said 72mph when I hit the cut off. That's telling me the cluster isn't that far off if the app is accurate though.
    Best free mod ever. Well worth going 3 up or 1 down in the front as its about the same
  1. Sprockets: What you need to know
    By kzam in forum Grom Performance
    Last Post: 09-13-2019, 07:28 PM
  2. Sprockets
    By gromhawk in forum Grom Performance
    Last Post: 07-05-2019, 01:20 PM
  3. +1/-1 or -2 sprockets anyone?
    By RACER X in forum Grom Performance
    Last Post: 07-17-2014, 12:37 PM
  4. Sprockets
    By OhioMiniGP in forum Grom Performance
    Last Post: 08-31-2013, 07:36 AM
  5. ok i need sprockets! HELP!
    By braaapgrom in forum Grom Talk
    Last Post: 08-23-2013, 01:02 AM
4 stud rear sprocket jt42
best sprocket combination for honda grom
crf 50 34t sprocket how will it affect bike
crf50 stock chain sprocket upgrade
grom sprocket
honda grom sprocket
pbi sprocket
standard grom sprockets
