FBM BIG BORE + FBM Turbo = 27hp and 19ft lbs !!
This is a discussion on FBM BIG BORE + FBM Turbo = 27hp and 19ft lbs !! within the Grom Talk forums, part of the Honda Grom Forums category; Sorry we haven't been too active on here. We finally got a chance to test our 200cc big bore with and without a turbo. The ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: FBM BIG BORE + FBM Turbo = 27hp and 19ft lbs !!
    Supporting Vendor
    Full Blown's Avatar
    3371
    14
    Sorry we haven't been too active on here. We finally got a chance to test our 200cc big bore with and without a turbo. The results are scary.. This big is INSANE to ride.
    Setup
    - FBM 200cc Big bore forged piston kit
    - FBM Stage 1 ported head
    - FBM HD Case/Head studs
    - FBM Turbo
    - FBM Custom Injector
    - DJ Power commander
    The purple line is the big bore without the turbo (20HP) , the blue line is BIG Bore + Turbo (27HP but alot more top end)
    a_morti and arunto like this.
    is Grand Poba
    2771
    Apr 2014
    Richmond, TX (just outside of Houston)
    1,145
    That's nutz!
    '00 VFR Sold
    '08 Busa Sold
    '10 Tuono Factory Sold
    '14 GROM
    125cc----->181cc of Takegawa Powa!
    4081
    Sep 2014
    Pittsburgh PA
    110
    77
    Nice work... BUT....
    You are asking a lot out of it... and the new cyl/head studs are great. BUT, are you threading them into the stock case? Or, are you putting in "Case Savers"? (can't tell from the pic)
    Back in the day... playing with air cooled VW's... we would pull the (aluminum) threads out of the case running high compression, or Boost. So, we would drill the case threads, and insert a threaded sleeve (steel) with a backer, so the studs couldn't pull out.
    Tony
    7,842
    Quote Originally Posted by RACER X View Post
    That's nutz!
    Yep that is great
    I wounder what the break down cost for each part.
    wondering about the connecting rod, is it OEM or HD?
    Just noticed on the pic the Crank shaft, so I'm sure that the connecting rod is special made for the engine
    4081
    Sep 2014
    Pittsburgh PA
    110
    77
    Actually... on second sight.... that cyl doesn't look like it's going to be very reliable. There's almost no "Meet" on the cam chain side. So.... 1) You will have really bad cooling at that point. and 2) it's not supported very well, so the cyl will wind up being oval shaped as it warms up... and 3) There's minimal head gasket clearance. With boost... that's just asking to blow out.
    For a 200cc cyl... you need a heavier casting to start with.
    Nice numbers... but I'll be more interested in hearing how it's doing after a few thousand miles.
    Tony
    Supporting Vendor
    Full Blown's Avatar
    3371
    14
    Quote Originally Posted by Dr Honda View Post
    There is a iron sleeve in it that is plenty thick. It will not oval out. Gaskets blowing out will be tough because it is not only relying on the gasket for a seal. We are building a second one for another customer and both will be heavily abused.
    is is the master tinkler
    RobbMeeX's Avatar
    534
    Jul 2013
    Grant Park, ATL
    1484
    421
    Moar pics of turbo!
    Black 2014, Brembo, Chimera, Dynojet, G'Craft, H2C, Kitaco, Koso, SP Takegawa, Vagabond, Yamamoto, Yoshimura...
    Quote Originally Posted by rolldeep View Post
    They said "we no even reset ecu bitch" and hung up.
    Supporting Vendor
    Full Blown's Avatar
    3371
    14
    is Groming in the Fort
    gromhawk's Avatar
    290
    Fort Wayne, Indiana
    683
    we need more!!!!!!!!!!!!!!
    2014 Honda Grom 170
    1999 Honda Nighthawk 750
    2002 Honda XR70R w/BBR 88 big bore
    Supporting Vendor
    Full Blown's Avatar
    3371
    14
  1. Turbo kit coming
    By Railer150 in forum Grom Talk
    Last Post: 03-09-2015, 12:16 PM
  2. GROM Turbo + Nos
    By overrev in forum Grom Performance
    Last Post: 07-02-2014, 07:41 PM
  3. Turbo or supercharge?
    By The_Grominator in forum Grom Performance
    Last Post: 03-08-2014, 06:56 AM
  4. Turbo the Grom!
    By Jefe's Grom in forum Grom Performance
    Last Post: 12-11-2013, 10:44 AM
  5. Honda Grom Turbo Kit?
    By 4Nines in forum Grom Performance
    Last Post: 06-06-2013, 08:06 PM
grom turbo
grom turbo kit
honda grom 200cc big bore kit
honda grom custom turbo
honda grom turbo
honda grom turbo kit
honda msx 125 turbo kit
turbo grom
