Synthetic Oil During Break In
This is a discussion on Synthetic Oil During Break In within the Grom Talk forums, part of the Honda Grom Forums category; Hi all, My name is Patrick and I am brand new to this forum. I recently got a grom a few months back after my ...
Results 1 to 10 of 17
Thread: Synthetic Oil During Break In
    pat-eye8's Avatar
    32082
    5
    Hi all, My name is Patrick and I am brand new to this forum. I recently got a grom a few months back after my 18th birthday, and about a month ago I rebuilt it with a new cylinder, finbro flat top piston, finbro oversized head and takegawa cam. Now please dont crucify me if this topic has already been asked, I did do a breif search and couldnt find much but I have around 500 miles on my motor since the rebuild and all has gone well except for the fact that I just realized I have ran full synthetic honda 10w-30 in it. I know they typically say dino oil for the first 1000 miles then synthetic after. Have I screwed myself now ? Should I just continue and use synthetic or change to dino for a while ? Should I sell my grom and never touch a motorcycle again ?
    855
    Patrick......relax......you did not hurt the engine.
    Since you already have 500 miles on a new (or rebuilt) engine, I would suggest doing an oil-change now. I say this not because the synthetic is *bad* for the break-in, but simply because it is common to liberate a few tiny metal fragments during the break-in, and it is prudent to do frequent oil changes during break-in because of this. You can run dino oil for the next 500 miles or so, then switch over to synthetic if you wish.
    277
    You blew it man. You should just get rid of your motorcycle. Since you seem like a nice guy, I'll do you a favor and take it off your hands. No need to thank me.
    In all seriousness Paul is right and follow what he says. I just wanted to be a smart ass. I'm sure you'll enjoy your bike for many more miles to come.
    is fiddling with RZ350's now!
    WV_Grom's Avatar
    4799
    North Central WV
    400
    946
    It just takes longer to break in a new/rebuilt motor on synthetic.
    Good advice above...
    2018 Grom
    Seat Concepts / Opmid V2
    8,119
    Just ride it like you stole it and remember to clean out the screen on the bottom of your crank case, this screen captures all the junk that comes of the engine moving parts.
    Ride safe
    MSX UD ITA's Avatar
    5772
    1500 km
    780
    Kitaco indicates ELF full sinth oil for neo break in (500 km) then same oil for the rest.
    ... They're stupid?
    668
    I hate synthetic oil. I have personally experienced the issues that people claim don't happen anymore specifically leaky seals after using synthetic. I am going to try to never use synthetic again.
    With that being said, there are cars that come from the factory with synthetic oils which means you are breaking-in that car on synthetic oil.
    2,360
    Literally use synthetic in EVERYTHING i own, from old ass motors to brand new, never been a leaky seal caused by syn.
    OP you are fine breaking in on synthetic.
    668
    Every synthetic oil fan says that, but I've personally experienced issues switching to synthetic. It's not hearsay.
    MSX UD ITA's Avatar
    5772
    1500 km
    780
    difference is risible, like a wasa whole grain crispbread and the maitre jean pierre crispbread , second costs half price and it's rough but nontheless good.... but if an engine seal has weird particularities like problems with sinth oils, doesn't mean all the other engines do the same.. more likely the crank doesnt match perfeclty and seals can't help... just an opinion huh
    nd4spdbh likes this.
