Changing Oil With Yoshimura RS-2
This is a discussion on Changing Oil With Yoshimura RS-2 within the Grom Talk forums, part of the Honda Grom Forums category; How are you guys changing oil without getting it all over your Yoshi RS-2 exhaust? I cut a water bottle to prevent the oil from ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Like Tree12Likes
Thread: Changing Oil With Yoshimura RS-2
    482
    I cut a water bottle to prevent the oil from the drain plug running onto the pipe, but how in the world do you take the side cover off without it dripping right onto the exhaust? All I can think of is putting a towel or drop cloth over the exhaust and hoping I don’t knock it off while removing the side cover.
    Attached Thumbnails Attached Thumbnails Changing Oil With Yoshimura RS-2-5ad75e37-19ec-4c88-b658-5f3ada3f8c0a_1559507424895.jpeg   Changing Oil With Yoshimura RS-2-c53e6ebd-055f-4085-8bad-336449d3a6b0_1559507465352.jpeg
    712
    just let it drip on the exhaust and clean it off with brakleen after? a bit of oil isn't going to ruin anything
    482
    That's obviously an option, but why? I mean I could skip a drain pan, drain the oil on the garage floor and then clean that up, but why would I do that? I'm trying to work smarter not harder. LOL Just seeing if people have some ideas and techniques that I haven't thought of.
    is enjoying the riding conditions
    GromMuleCa's Avatar
    29624
    Aug 2018
    North Bay Area, Ca
    1463
    173
    I used aluminum foil, and I’ve used a HardRacing trick with a plastic USPS shipping envelope. Any oil that got on pipe came off easily w/WD40.
    2018 Grom White, Yoshimura pipe, Kitaco clutch cover kit, Takegawa Super oil pump, Kitaco clutch springs, HR billet clutch plate, Vagabond rack w/fender eliminator, K&N filter, Pro-taper Mini Hon bar, OPmid 2 temp/volt meter, PV3 flash tool, Koso TT mirrors, OTB Gen 2 billet chain adjuster w/spools
    1SickVeilsideZ's Avatar
    23138
    Inland Empire 909/951
    53
    I do the same and use aluminum foil or padded envelope like hard racing showed in one of the videos they made.
    1844
    Nov 2013
    89
    I did it this way, I use gyeon prep to clean up.. it takes 2secs to wipe down the exhaust which is not a big deal.
    482
    Quote Originally Posted by Bonafyd View Post
    I've never heard of Gyeon, but the Yoshi manual recommends "Bar Keeper's Friend" which I've also never heard of. I picked up some of the "MORE" version at Lowe's. It does seem like a good cleaner. It removed a lot of junk and things that look like stains. The more baked on stains either need a lot more soak and scrub time and elbow grease or maybe some of the more abrasive flavors of Bar Keeper's Friend.
    I like the aluminum foil idea. Even some shrink wrap would probably work. You'd just have to remember to remove it before starting the bike. That what he messy if you forgot to remove it.
    GromMuleCa's Avatar
    29624
    Aug 2018
    North Bay Area, Ca
    1463
    173
    To remove oil or baked on stains, use a soaked dryer sheet in Dawn dishwashing soap also does a great job, environmentally safe too.
    tooter and 50-50 like this.
    592
    Same here.
    Foil works nicely because it can easily be molded to the pipe and won't slip off.
    2018 GROM: Modified for reliability and gas mileage.
    1844
    Nov 2013
    89
    Gyeon prep is an IPA cleaner. bar keepers friend is"Non abrasive" polish 2 different approaches that both work.
    I'd use bar keepers friend to remove a stain on the yoshi or even glass since it's a non abrasive "polish" but for a quick wipe down any IPA soloution works.
    my power washer & snow blower recommends ethanol shield brand fuel stabilizer which i've never heard of before in my life. I use sta-bil and they still start with no issues.
