No clutch after installing koso lifter plate.. - Page 4
This is a discussion on No clutch after installing koso lifter plate.. within the Grom Talk forums, part of the Honda Grom Forums category; I emailed them over the weekend, but they haven't replied back yet. They've replied to my emails before......
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 39 of 39
Like Tree2Likes
Thread: No clutch after installing koso lifter plate..
  1. #31
    2205
    Orlando, Florida
    168
    mikochu
    2018 Honda Grom (Matte Gray)
    Suspension:
  2. #32
    15809
    Feb 2017
    Southern ME
    47
    So this appears to be a koso problem. I just installed one and am having the same issue as everyone else. I did 2 other groms with different plates with no problem. Did they ever get back to you?
  3. #33
    28273
    97
    I have built 4 groms using the koso plates with no issues, make sure that the springs are correctly seated and that the clutch disks are correctly seated in the basket
    2015 Grom - High Compression 125 Build
    2018 Grom - 143cc BigBore
    1986 Spree - 70cc BigBore
    2017 DRZ400SM
  5. #34
    15809
    Feb 2017
    Southern ME
    47
    Springs are seated properly and discs were never touched so they should be fine.
  6. #35
    2205
    Orlando, Florida
    168
    No, they never got back to me.
    mikochu
    Suspension:
  7. #36
    28273
    97
    Quote Originally Posted by justin_l_ View Post
    double check the disks
    2017 DRZ400SM
  8. #37
    15809
    Feb 2017
    Southern ME
    47
    Double checked the discs, and spring seating. Both good.
  9. #38
    557
    Jul 2013
    228
    I just got mine yesterday and this is slightly worrisome.
  10. #39
    28273
    97
    Top of the clutch pack flush with the basket?
    Im installing another koso plate tomorrow and a smr 6 disk.
    your problem is weird unless there's a batch of them that are machined wrong or something where did you get it from?
    2017 DRZ400SM
  1. Clutch no longer works after oil change
    By g0nk in forum Grom Talk
    Last Post: 10-07-2018, 10:48 AM
  2. HELP! Broke bolt installing clutch plate
    By Jaygrom in forum Grom How-To's and Guides
    Last Post: 11-22-2015, 09:02 AM
  3. Replies: 7
    Last Post: 11-10-2014, 09:04 PM
  4. Replies: 2
    Last Post: 11-10-2014, 07:03 PM
  5. Replies: 5
    Last Post: 04-08-2014, 06:25 PM
koso lifter plate grom
koso plate grom issues
