420 to 428 chain upgrade??
This is a discussion on 420 to 428 chain upgrade?? within the Grom Talk forums, part of the Honda Grom Forums category; Whar are the benefits of going to a 428 cain over the 420? Does it have any effect on top speed? Cheers...
Results 1 to 9 of 9
Like Tree9Likes
  • 4 Post By mikochu
  • 3 Post By x-reaper
  • 1 Post By dubSolo
  • 1 Post By ditchbaby
Thread: 420 to 428 chain upgrade??
    7751
    UK
    9000
    238
    Cheers
    2205
    Orlando, Florida
    161
    From what I've read, it introduces more drag, so it has the potential to slow you down...?
    mikochu
    2018 Honda Grom (Matte Gray)
    Suspension:
    28273
    92
    Both my bikes are running the 428 kit from sprocket center. I installed one set last summer and have about 1000 miles on it now with the 428 kit. I didn't get the oring chain just the regular gold chain. I did a speed run before and after and got the same speed. And I haven't had to adjust it yet!
    5746
    San Francisco
    1142
    273
    Quote Originally Posted by damoC View Post
    Cheers
    You need the 428 chain if you have a BBK.
    235 2 Valve
    Supercharged AMG C43
    BMW M3
    2017 GSXR 750
    5834
    140
    D.I.D. 420NZ3 is stronger and better looking chain option, and no loss in power.
    obijuanito, Djezspin and fat831boy like this.
    Quote Originally Posted by x-reaper View Post
    I stuck with the 420NZ3 chain as well, no o-ring. 428 chain would be slightly stronger than the 420 but not enough in my opinion to justify the additional 1/2 pound increase just from the chain alone, then you add the front and rear sprockets to that list it all adds up.
    is 8.5.Zer0's Fastest!Grom
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    712
    Also started out with the DID 420NZ3,,, I still had to adjust at least every two weeks, which was better than stock chain every 3 to 4 days...
    Replaced the DID with a Renthal R1 420 chain, this chain came heavily waxed out of the package which the DID didnt (DID purchased from Sprocket Center)
    Have had this Chain for two months this past weekend was the only time Ive adjusted and only did so cause I wanted to clean and re-wax it.
    Not saying anything wrong with DID 420 NZ3, But for me there was a better difference going to renthal
    https://www.amazon.com/Renthal-C241-.../dp/B002AQ42KG
    Djezspin likes this.
    Super!Stock 2018 DSR Honda Grom
    Dhm Custom Hi Comp Piston
    Dhm Race Ported Cylinder Hd
    Dhm Velocity Intake Dcr2 Cam
    Hindle Exhaust Stock Ported TB
    Lightend Flywheel and Oil spinner
    Takgawa Crank Support 4th Bearing
    Takgawa Hi Ign Coil w/NGK Race Cable
    Takgawa Hi Flw Oil Pump w/Opmid Gauge
    EBC Srk122 kit Billet plate w/SMR Springs
    EBC Brake Pads w/ Wave Rotors
    SpeedLinez Brake Lines w/Short Levers
    Ohlin Fork Springs, Ohlin HO 424 Rear Shock
    GF Billet Vented Cam Cover and Speed Spacers
    Good to know, I've never ran a Renthal chain but I'll keep that in mind and take a look at them.
    6888
    Feb 2016
    44
    I went with a DID o ring chain, and I did notice the bike is not as fast.
    mikochu likes this.
  1. Replies: 1
    Last Post: 07-10-2017, 09:59 PM
  2. FS: SUPERLITE Sprocket set w/RK 420 Chain NEW 32T - 16T
    By loaded in forum Parts for Sale / Wanted
    Last Post: 12-05-2016, 10:39 PM
  3. 428 Chain Upgrade
    By a_morti in forum Grom Performance
    Last Post: 05-28-2016, 12:22 PM
  4. Replies: 6
    Last Post: 08-07-2015, 07:51 AM
  5. FS: D.I.D 420 Chain kit with sprockets
    By GrommerGirl in forum Parts for Sale / Wanted
    Last Post: 02-15-2015, 03:44 PM
