Fuel Consumption
Fuel Consumption
This is a discussion on Fuel Consumption within the Grom Talk forums, part of the Honda Grom Forums category; Have you guys noticed an increase of fuel consumption just by replacing the stock exhaust? The Grom is supposed to make 134mpg but I'm afraid ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
Like Tree11Likes
Thread: Fuel Consumption
    john2018's Avatar
    30984
    Los Angeles, California, USA.
    1,768
    141
    Fuel Consumption
    The Grom is supposed to make 134mpg but I'm afraid I'm just getting around 80mpg.
    Grom 2018 Modifications:
    Yoshimura RS-2, Vagabond Cargo Rack & Fender Eliminator, GIVI Top Box.
    Gold Supporting Member
    is Wishing I was riding....
    MNNTHBX's Avatar
    17
    Knoxville TN
    1,783
    Bikes in higher states of tune, and bikes ridden harder, will always return less fuel economy, however I'd consider 80mpg the be far better than the alternatives.....
    Top Shelf parts & accessories WWW.MNNTHBX.COM
    8,214
    Did you do a base test first when you got your grom and do at lease 5 gas refill to see what your baseline mpg is for your style of riding than do the mod and see how much your mpg goes down. That is what I did I first wrote down all the baseline performance of my stock grom and as I slowly added performance parts I documented any changes in performance or mileage.
    Even my 181-4v, 34mm throttle body 10 hole F/I will get close to 100mpg if I ride it normal and not do a speed freak thing but if I ride it like I stole it I get 80mpg.
    Hopefully you did a ECM reset when you installed the aftermarket exhaust system, make sure your air adjustment needle on your throttle body is adjusted for good performance and make sure your air filter is clean or new.
    Try various grade of gas, 87-89-93 octane and see which one gives you the best performance and mileage.
    Good Luck and ride safe
    777
    I ride my Grom for daily utility transportation so I use gas mileage as an indicator of how efficiently the engine is running. My average is 138.8 mpg.
    john2018's Avatar
    30984
    1,768
    141
    Even my 181-4v, 34mm throttle body 10 hole F/I will get close to 100mpg if I ride it normal and not do a speed freak thing but if I ride it like I stole it I get 80mph.
    Well, when I just got it, I rode like a grandma because it was in the breaking in period, I did not know how to drive that much and I did not have a driver license but now I drive it like I stole it. I'm cruising at 7k rpm constantly, 50mph ~ 55mph. I use 91 octane only, I drive about 34 miles round trip every day. I'm refilling every 2 days, tank is almost empty after 68 miles or 2 days.
    By the way, I'm 5'5" and 145 lbs before lunch
    8,214
    Quote Originally Posted by john2018 View Post
    wasting money at 91 octane, just use 87 until you do a BBK kit 170cc or larger.
    We use to fill up our 99 Hayabusa with 91-93 octane back in 1999 until someone from our Hayabusa group did a test and said 87 octane works just as good for the busa and that is what I've been using for my 99 hayabusa.
    at your wt you should be hitting 60-65mph if your break in engine has over 2K on the speedo. My 2014 grom hit 60-65mph after 2-3k miles of break in and back then I wt 225 lbs, now that I'm dieting down to a goal of 195 lbs I'm seating at 207-211.
    So I assume there is something wrong with your grom, check your tire pressure, check and clean your drive chain and I would go back to stock setup and see if your mileage goes up, also recheck your spark plug color to see if it is normal dull brown, or black or ash white.
    Good luck
    john2018's Avatar
    30984
    1,768
    141
    Thanks, I'll try 87 octane. By the way, do you know if the reserve works after the tank is fully empty? How does the reserve works? Thanks.
    no reserve on a Grom, my fuel gauges starts to flash (last bar) with roughly half a gallon of fuel left. I wouldn't be taking sharp extended turns with the gauge flashing as you'll probably starve the engine of fuel. Hell, just sitting on the side stand and my gauge is one bar lower than with the bike standing upright.
    8,214
    ^^^^^^^what he said^^^^^^
    is just riding.
    Fat Will's Avatar
    4958
    Mar 2015
    Lancaster, PA
    7600
    255
    I couldn't hit 80mpg's if I tried, mine has always been triple digits. '15 with Chimera intake, Tyga exhaust, EJK fuel controller and I'm 220lbs (give or take). I think the worst I've gotten was 112mpg and that's riding it hard. And always use 87 Octane.
  1. TB cam = fuel starvation - injector or fuel hose
    By Reeny in forum Grom Performance
    Last Post: 04-29-2018, 02:25 AM
  2. Akrapovic Slip on any mods required? Fuel consumption?
    By timmysd88 in forum Grom Gear and Accessories
    Last Post: 08-03-2015, 06:45 AM
  3. Replies: 32
    Last Post: 09-30-2014, 05:04 PM
