Kitaco Upgraded STARTER MOTOR H-D Finally....
This is a discussion on Kitaco Upgraded STARTER MOTOR H-D Finally.... within the Grom Talk forums, part of the Honda Grom Forums category; Kitaco Upgraded STARTER MOTOR (Heavy Duty) - P.N. 758-1432100 Fits : Honda Grom OG / SF / MONKEY Key Points: - Improved Starting Performance - ...
Results 1 to 10 of 12
Like Tree5Likes
Thread: Kitaco Upgraded STARTER MOTOR H-D Finally....
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    Charlotte, NC OHLINS_MASTER_DEALER
    3,898
    P.N. 758-1432100
    Key Points:
    - More Torque
    - OEM Fit
    Highly Recommended when doing a Big Bore Kit Upgrade
    KITACO HD STARTER <<
    HardRacing.com - 704-799-2192
    See our complete >> GROM PARTS CATALOG << >> MONKEY PARTS CATALOG<<
    Check out our Youtube Channel for Lots of Great Parts Installation Videos >> YOUTUBE CHANNEL<<
    Ohlins Premier Dealer, Great Prices, Tech.Support, Full Staff of Sales Reps, Fast WORLD WIDE Shipping,
    Large Inventory and Excellent Customer Service.
    Celebrating our 20th year in business
    2,112
    Sooo... Umm... Any stats on it? Power? Torque?
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    3,898
    That's a very good question.
    Waiting for Kitaco to give an answer.
    3919
    Sep 2014
    Albany, NY
    150
    113
    Thanks for asking, HR. I’ve been curious about this starter. I’m guessing it was recently released? Haven’t seen any listed until recent.
    7,644
    Seem cheaper than buying a OEM starter which is around $112
    found some info on the product
    This is a reinforced electric starter motor specially designed by Kitaco Co. in Osaka, Japan.
    It fits Honda Grom 125 all models.
    We all know that it is nearly impossible to use genuine one when you install a big bore kit on your vehicle.
    Here is THE solution, no more pain starting your engine using this PLUG & PLAY hi quality model.
    Fittings are similar as genuine one therefore it is very easy to install.
    We recommend to use a stronger battery to get optimal performances.
    Here are several technical informations from manufacturer:
    DESCRIPTION
    DEVELOPED FOR HIGH TUNED MOTOR. STRONGER STARTER MOTOR HELPS YOU START ENGINE EASILY.
    REMARKS
    ○KITACO STARTER MOTOR COVER USABLE
    ※BATTERY REQUIRES ENOUGH POWER (NEW BATTERY RECOMMENDED).
    ※DISASSEMBLY NOT ALLOWED
    APPLICATIONMONKEY125JB02 ALL MODELGROMJC61 ALL MODEL
    JC75 ALL MODELSUPER CUB C125JA48 ALL MODEL
    MSX UD ITA likes this.
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    3,898
    Finally installed it.
    WOW.... definitely, a big improvement over stock.
    Only took about 5 min to install with 2 wrenches.
    Super Easy.
    mikochu likes this.
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    3,898
    Quote Originally Posted by Yfz460 View Post
    Correct.
    Brand new product, just released.
    Unfortunately, Kitaco says they won't have more for 3-4 months.
    We will most likely sell out of our Stock on these in the next 24-48 hrs............. Frustrating.
    Boyjeenyus's Avatar
    15977
    Feb 2017
    Tennessee, or all over the country
    80
    I installed mine yesterday. Super quick n easy install, and now it starts like a normal bike again! Since doing the NEO kit, it has required a combination of multiple bumps on the starter button, and occasionally having to roll it back off the compression stroke to make it start--even with a lithium battery in good shape. Stoked to not have to worry about this stuff anymore! thanks HR and Kitaco!
    Stephen
    Happy Customer
    HardRacing and GROM_MSX like this.
    2014 Grom Red/Yellow
    1973 Honda CL350 Scrambler
    2010 Genuine Rattler 110
    4bt-powered home-built Freightliner MT35 RV.
    "I like to tinker"
    7,644
    I did order 2 of these starters since it was such a good price on spring break sale overseas and it will be spares in case my 2014 OEM starter dies. Yes it is a 2-3 month wait to get these starters but cheaper than a HD Finbro starter.
    I figure it will be going up in price also so I had to grab 2
    HardRacing has good prices and fast shipping if the product is instock
    HardRacing likes this.
    7,644
    Hey HR that polished cover for the Kitaco oil filter did you polish it yourself or can you buy it with the polished allen bolt???
  1. 2014 Starter Motor Stuck On
    By Coupcake in forum Grom Performance
    Last Post: 02-18-2018, 05:07 PM
  2. Replies: 12
    Last Post: 04-23-2016, 06:15 AM
  3. Hard time start the 218cc finbro engine with stock starter motor
    By brightheatx in forum Grom Performance
    Last Post: 02-05-2016, 10:18 AM
  4. stronger starter motor
    By hobbycaptain in forum Grom Performance
    Last Post: 09-15-2015, 10:20 AM
  5. Honda Grom MSX125 CR Starter Motor Covers
    By MSX125Accessories in forum MSX125Accessories.com
    Last Post: 08-15-2015, 09:34 AM
Tags for this Thread
