4th bearing flywheel support and modified oil hole question
This is a discussion on 4th bearing flywheel support and modified oil hole question within the Grom Talk forums, part of the Honda Grom Forums category; This question is for those BBK kit engine builders that have installed the 4th support bearing in your flywheel case cover, did you do the ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Like Tree6Likes
Thread: 4th bearing flywheel support and modified oil hole question
    7,623
    This question is for those BBK kit engine builders that have installed the 4th support bearing in your flywheel case cover, did you do the mod where you drilled a hole in the case near where the bearings mount so that the bearings will get oil dripping on it or you just mounted the bearing and the hold down plate and be done?
    I have both the old and new 4th bearing support since I up graded one of my 2014 grom engine with 2017 stator and rectifier. I did noticed that on the old grom 4th bearing support kit the hold down plate had zero spacing so I assume that oil will not drip down into the bearing for lube and the 2017 newer 4th bearing hold down plate seems to have a little spacer style design that looks like oil can slip down into the bearings.
    Talking to a few BBK kit grom owners in San Jose that have done the 4th bearing support upgrade they did noticed that the bearing esp on the 2014 style support unit seems to wear out a little faster and that is why the modified drill hole is needed to lube the bearing.
    Anyone noticed any difference if they drilled their flywheel case to help the 4th bearing support lubing or you just mounted the unit and let it be.
    3,619
    drilled mine up top, as far towards the outside of the cover as i could. just had the cover off, bearing looks great. i also countersunk the hole a bit to act as an oil well.
    532
    I drilled and countersunk mine just like m in sc. When I open the center access plug on the cover, there's always a good amount of oil there.
    448
    Same, always oil in the bearing when I remove the inspection plug.
    Kitaco NEO 181 2V / Takegawa Oil Pump, Cam Chain Tensioner, Crank Support Kit & Catch Can
    DynoJet PCV, WB2 & AFR / OPMID 2 Temp / RPM Dual Gauge Mount
    Koso 34mm TB / Drow Sports CF Intake & Oil Cooler / Hindle Exhaust / Port Matched Head
    Michelin PP SC2's / EBC Vee-Rotors & HH Pads / 15/32t & 420NZ3 Chain / SpeedoDRD
    is 8.5.Zer0's Fastest!Grom
    dubSolo's Avatar
    27817
    Mar 2018
    Florida, Respect the Locals and our Beach! Keep it Clean...
    6,661
    665
    Quote Originally Posted by Djezspin View Post
    What size drill bit and did anybody take pictures??? The bearing kit came in today, might do this weekend.
    448
    https://www.hondagrom.net/forums/27-...m-build-5.html
    I know I started out with a 1/16" bit, then worked my way up to 1/4". It's big but I have lots of oil. I started small and worked up to 3/32" on the lower hole. My bike has been sitting for almost an hour and you can see there is still oil on the bearing and in the cover so seems to be working perfectly.
    4th bearing flywheel support and modified oil hole question-7bgcozxirh-ccaijmkthwa.jpg4th bearing flywheel support and modified oil hole question-tlymp4vxrxcrsz3avimg3a.jpg4th bearing flywheel support and modified oil hole question-n1gvxdqbtdmddoz5imfltg.jpg
    Damn photos got rotated 90 degrees counterclockwise. Obviously the bigger hole is at 12 o'clock and little hole is at 6 o'clock
    I originally tried to drill from inside the inspection cover as you can see by the little nub next to the 1/4" hole. It didn't work out so I drilled both holes from the backside to the cover in towards the inspection port.
    Top hole is countersunk on topside, bottom hole is just a hole, no countersink as I'm not concerned with trying to get the oil out of there and back into the sump.
    lol, last edit...bottom hole works great because I don't ever get oil leaking out all over the place when I remove the inspection hole plug, as long as I let it sit for about an hour first.
    dubSolo and MSX UD ITA like this.
    3,619
    i think i used a 6mm. ? honestly don't remember.
    532
    wow....you guys went big. I think I only went up to about 1/8"
    7,623
    Thanks for all the info and pic, are most of these pre-2017 groms 2013-16 with the old stator unit or any with the newer stator unit which needs the newer 4th bearing support bearing plate.
    Ride safe all
    MSX UD ITA's Avatar
    5772
    1500 km
    709
    Yesterday I received my kit. I will definitively copy OPs drilling setup
    Inviato dal mio WAS-LX1A utilizzando Tapatalk
  1. Replies: 3
    Last Post: 02-07-2019, 06:59 AM
  2. Replies: 2
    Last Post: 01-30-2019, 06:17 PM
  3. Replies: 6
    Last Post: 01-30-2019, 10:17 AM
  4. Takegawa 4th crank bearing support sound
    By x-reaper in forum Grom Performance
    Last Post: 09-09-2017, 01:34 PM
  5. Replies: 26
    Last Post: 07-12-2017, 12:06 PM
