4th bearing flywheel support and modified oil hole question - Page 2
This is a discussion on 4th bearing flywheel support and modified oil hole question within the Grom Talk forums, part of the Honda Grom Forums category; Can someone make a video of where to drill the hole to lube the bearing?...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Like Tree6Likes
Thread: 4th bearing flywheel support and modified oil hole question
    5746
    San Francisco
    1142
    273
    235 2 Valve
    Supercharged AMG C43
    BMW M3
    2017 GSXR 750
    MSX UD ITA's Avatar
    5772
    1500 km
    746
    I drilled it yesterday.. No video sorry.. But when you have the piece in hands seems pretty clear where to drill.. There's no big choice. I drilled directly on the thread with 7mm screw
    Inviato dal mio WAS-LX1A utilizzando Tapatalk
    5746
    San Francisco
    1142
    273
    Quote Originally Posted by MSX UD ITA View Post
    Mine is already installed, installed long time ago just not drilled.
    235 2 Valve
    BMW M3
    2017 GSXR 750
    is 8.5.Zer0's Fastest!Grom
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    694
    I did noticed that on the old grom 4th bearing support kit the hold down plate had zero spacing so I assume that oil will not drip down into the bearing for lube and the 2017 newer 4th bearing hold down plate seems to have a little spacer style design that looks like oil can slip down into the bearings.
    Anyone,,, just mounted the unit and let it be.
    YES! Looks like you are Correct Cisco, figured I'd mount mine without drilling the hole just to see.
    A weeks worth of riding, looks good.
    Attached Thumbnails Attached Thumbnails 4th bearing flywheel support and modified oil hole question-_20190414_184749.jpg   4th bearing flywheel support and modified oil hole question-_20190414_185159.jpg
    Super!Stock 2018 DSR Honda Grom
    Dhm Custom Hi Comp Piston
    Dhm Race Ported Cylinder Hd
    Dhm Velocity Intake Dcr2 Cam
    Hindle Exhaust Stock Ported TB
    Lightend Flywheel and Oil spinner
    Takgawa Crank Support 4th Bearing
    Takgawa Hi Ign Coil w/NGK Race Cable
    Takgawa Hi Flw Oil Pump w/Opmid Gauge
    EBC Srk122 kit Billet plate w/SMR Springs
    EBC Brake Pads w/ Wave Rotors
    SpeedLinez Brake Lines w/Short Levers
    Ohlin Fork Springs, Ohlin HO 424 Rear Shock
    GF Billet Vented Cam Cover and Speed Spacers
    28273
    88
    dub that is exactly how mine looks to with no hole drilled.
    You've got oil being fed to it. The instructions don't even say to do it. I'm not even sure if it was a big problem. I haven't been able to find many reported problems like you can find for the Koso lift plate and this whole drilling an oil port thing probably just stems off an isolating incident.
    28273
    88
    I got three groms running the koso plate also with no issues lol
    Djezspin and MSX UD ITA like this.
    3,716
    there were reports early on of them squealing which is what prompted it. theres -zero- downside to drilling it.
    Djezspin likes this.
    7,838
    I think the 2014-15 year groms which used the older style stator had problems due to the way the hold down 4th bearing plate was manufactured to secure the bearing in place which had no space or machined slots to let the oil drip down, the 2017 and newer groms stator was designed a little different and the hold down plate for the 4th bearing had gaps machined on the plates so it would fit in the newer stator.
    So for grom owners who have the older 2014 groms pre-2017 grom if your stator goes out/fails it is cheaper to buy a 2017 stator and upgrade your rectifier to the newer 2017 unit at the same time, and when you buy the fourth bearing support make sure you buy the correct kit to match the year of the stator you installed. I did upgrade both of my 2014 groms to 2017 stator and rectifier and the reason why was it seems it had a better output voltage and there was no need to buy a special rectifier to run my LED head lights, LED blinkers, LED tail/brake lights and the only problem I have is burning up my LED license plate bulb circuit trace due to too much current or voltage draw to that unit and that is why I posted a section on if I need to add a certain valve resistor inline with the wire to the license plate + voltage side of the circuit.
    is "Working"
    Wicked_VFR's Avatar
    19169
    New Hampshire
    6,200
    97
    170BBK, Did the oil mod for the 4th bearing. No need for a bottom hole. Gravity takes care of that. No issues.
    m in sc likes this.
    2017 Honda Grom SF
    [ Koso 170bbk | Koso 34mm TB | Koso Cam | Koso Cam Chain Tensioner | PCX150 Injector | Aracer MiniPlus2 W/ Wideband | Drow Carbon Intake | Brembo P32s w/ VEE Rotors | Ohlins Suspension | GromFatherz Manual Tensioner, Headstuds, Speed Spacers | Carbon Fiber Everything | ]
  1. Replies: 3
    Last Post: 02-07-2019, 06:59 AM
  2. Replies: 2
    Last Post: 01-30-2019, 06:17 PM
  3. Replies: 6
    Last Post: 01-30-2019, 10:17 AM
  4. Takegawa 4th crank bearing support sound
    By x-reaper in forum Grom Performance
    Last Post: 09-09-2017, 01:34 PM
  5. Replies: 26
    Last Post: 07-12-2017, 12:06 PM
