Clutch no longer works after oil change
This is a discussion on Clutch no longer works after oil change within the Grom Talk forums, part of the Honda Grom Forums category; OK, so I did my first oil change today at 600 miles. I cracked open the casing and pulled it out just enough to clean ...
Results 1 to 10 of 11
Like Tree7Likes
Thread: Clutch no longer works after oil change
    g0nk's Avatar
    29526
    Aug 2018
    CVille, VA
    11
    OK, so I did my first oil change today at 600 miles. I cracked open the casing and pulled it out just enough to clean the little screen inside, and put it all back together. I had to pop out the clutch cable of course to get the case to come off enough..
    Now the clutch doesn't work. The lever has absolutely no spring to it at all, no resistance. The little lever at the end of the clutch cable seems lose as hell and the whole thing lifts up. I am gonna guess this isn't normal. But now I really do not know what to do. What happened? I didn't even adjust the clutch cable or mess with anything internally.
    I have since tried to adjust the clutch all the way in and out at the lever and then at the master adjuster and it's still non-functional. Any help would be great. I'd hate to have to drain the oil and everything again to go back in there. Just put a quart of Motul in there..
    2018 Honda Grom - Pearl White #StormScooter
    Instagram: @g0nkdr0id
    YouTube Channel:
    https://www.youtube.com/RideWithGonk
    is 8.5.Zer0's Fastest!Grom
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    798
    Gonk sorry my man your going to have to take back apart,,, your plunger which engages the clutch plate has come out of its track... You will see what I mean when you take back apart
    g0nk likes this.
    8,201
    ^^^^^^yep that is what happened^^^^^^^
    look on the cover and see when you activate the clutch lever you should see the plunger move or go in and out.
    good luck
    g0nk likes this.
    Here you go Gonk, courtesy of Photogromers video. His right thumb is basically pointing right at the black plunger.
    Clutch no longer works after oil change-screen-shot-2018-10-06-3.12.42-pm.png
    g0nk likes this.
    g0nk's Avatar
    29526
    Aug 2018
    CVille, VA
    11
    Oy vey... I knew it, but didn't want to believe it.. So dumb question, do you guys think if I drain the new oil out, I can put it back in? I only ran the engine for about 5 minutes after putting everything back together.
    Thanks guys!
    YouTube Channel:
    8,201
    Quote Originally Posted by g0nk View Post
    Thanks guys!
    I've done it many times before esp on the grom.
    Same here as well, just don't contaminate the oil in a dirty pan or anything, lol
    is Never thought stock bore could
    be so good
    estallings15's Avatar
    7251
    10,500
    1,542
    This is one of the main benefits of the aftermarket clutch cover. Not having to remove that freaking side cover every oil change. Been there, dude. Taking that thing back off is a bummer.
    Paultergeist likes this.
    Takegawa 12.5:1 Piston
    Ported Head w/ TB valves
    2" Intake w/UNI filter
    DanMoto conical exhaust (no kidding)
    g0nk's Avatar
    29526
    Aug 2018
    CVille, VA
    11
    I really thought about getting that Kitaco clutch cover about a month ago, but I can't blow the money on it at the moment. It's going back on my shopping list now though..
    estallings15 likes this.
    YouTube Channel:
    g0nk's Avatar
    29526
    Aug 2018
    CVille, VA
    11
    Hey guys!! Wanted to just say thanks again! This morning I took it all apart again, and just as you all said, that little plunger was sitting at the bottom of the casing. Probably fell out as I pulled the casing off this morning because I felt something fall as I pulled it off.. But everything is back in and properly working. Works like a charm now! Just need to adjust the lever a bit, works great but just needs a little adjustment over the next couple days probably.
    YouTube Channel:
  1. Potential problem after oil change
    By QuinnJ86 in forum Grom Talk
    Last Post: 10-23-2018, 03:32 PM
  2. Replies: 53
    Last Post: 07-02-2018, 12:20 PM
  3. Replies: 3
    Last Post: 01-05-2018, 08:44 PM
  4. Help! Display no longer works....
    By hue_hue in forum Grom Talk
    Last Post: 09-28-2016, 03:58 AM
  5. No oil change
    By GentleGrom in forum Grom Talk
    Last Post: 08-10-2016, 12:29 AM
