Installed ARacer Mini 5 — Temp Gauge Now Seems Off? - Page 2
This is a discussion on Installed ARacer Mini 5 — Temp Gauge Now Seems Off? within the Grom Talk forums, part of the Honda Grom Forums category; I’m all for DIY, so bravo!...
Results 11 to 15 of 15
Thread: Installed ARacer Mini 5 — Temp Gauge Now Seems Off?
    28362
    75
    830
    Yeah, you're not going to get much out of just the ECU and exhaust. I really felt a boost in power when I did the TB cam. If you get a cylinder head temp gauge, you can try advancing the timing in the upper rev range.
    Hi Johnny,
    Thanks for sharing your thoughts. It seems like there is always one more thing to buy, THEN I’ll really notice a difference in performance. I was reflecting on the Brock’s YouTube videos, where he pretty clearly gains another 5 MPH top speed with a modded air-box, an exhaust, and a fuel controller. I was hoping to see similar results. Of course, he is a professional who knows what he is doing. At about $800 all-in for the Hindle exhaust and the ARacer, I am really hoping to see more than a 1 MPH (maybe) increase in top speed. Still more experimenting to do.
    i do not understand the reference to the cylinder head temperature gauge in order to advance the timing. Can you elaborate?
    pwr2wh8's Avatar
    2075
    SoCal
    1,008
    by advancing timing, you are trying to increase power output. however, there's a risk of running hotter due to detonation so you need to monitor temps
    Paultergeist likes this.
    808Ray's Avatar
    26874
    Jan 2018
    Hawaii
    35
    The Oem ecu and aracer both run on +5v reference to oil temp sensor, however the aracer has different impedance (internal resistance) so the voltage differs. I have opmid and with Oem ecu at 89f yellow wire is at 2.6v. Same temp with aracer it’s 3.9v. My opmid reads 40f cooler then actual.
    I tried playing with my variable resistor box and even tried some fixed resistor in line to opmid to lower voltage and initially looked like would work but not enough load. On the pc5 pod-300 you can set voltage to temp cross reference but not for aracer lol.
    For now now I use the aracer app gauges and opmid + 40f. Maybe aracer will update app to show Fahrenheit in future. -88ff9ac5-3ac3-4488-bbdc-7b5a14e28e00.jpeg
    632
    This sentence perfectly captures the Grom struggle. LOL
    The trail tech TTO 10mm temp gauge is only $45 on eBay. It'll give you piece of mind. I look at it more than the AFR readings now.
  1. Replies: 15
    Last Post: 08-14-2018, 09:53 PM
  2. Aracer Rc mini 4c + Mini tune gauge
    By Adamt85 in forum Parts for Sale / Wanted
    Last Post: 12-10-2017, 01:27 AM
  3. Replies: 12
    Last Post: 11-29-2017, 11:08 AM
  4. Replies: 13
    Last Post: 07-15-2016, 09:51 PM
  5. Replies: 14
    Last Post: 05-13-2015, 04:35 AM
does aracer rc5 have temp sensor
