Engine seized after 2200km - Page 2
This is a discussion on Engine seized after 2200km within the Grom Talk forums, part of the Honda Grom Forums category; Originally Posted by CiscoSanJose time for a BBK, either the super head 125cc or the NEO 181-2v kit or if you want to really go ...
Results 11 to 18 of 18
Like Tree7Likes
Thread: Engine seized after 2200km
    is GROMLIN
    CADGROM's Avatar
    19033
    Apr 2017
    LETHBRIDGE, AB
    7500
    118
    time for a BBK, either the super head 125cc or the NEO 181-2v kit or if you want to really go fast the Koso 170-4v kit.
    WOAH! baby steps cisco, we still gotta get him to check him oil first... then maybe change it himself.
    2017 HONDA GROM.
    2017 HONDA CIVIC HATCHBACK TURBO.
    1969 HONDA S90
    1990 CHEVY S-10 SLAMMED V8 SWAPPED.
    11217
    28
    100% your fault. Kinda makes that 10 seconds it would have taken to check it seem miniscule
    NorCalGrom's Avatar
    2480
    Mar 2014
    683
    It's a mistake. We all make them everyday. You, or no one else, was physically hurt as a result. Worst case it costs you money to remedy. Lesson learned. Move forward.
    Bluechain's Avatar
    32352
    Syracuse,NY
    21
    Crazy reading stories like this, its a machine, it only holds qt, it should be changed every 800 mile after the first change at 200 miles or less....I did mine at 100,300,600,..
    checked before every ride along with tire pressures
    32676
    Sep 2019
    6
    The postie 110CC bikes have a very similar engine. If Peter Steven's or Honda won't do a warranty deal see if you can find an independent mechanic to swap out the cylinder and piston for a used set if that's all you can afford. It's a 2 hour job or so.
    32366
    38
    FYI, this thread is almost two years old (in case people are thinking about replying without checking the dates). I'm sure the OP has moved on.
    is fiddling with RZ350's now!
    WV_Grom's Avatar
    4799
    North Central WV
    400
    960
    Regardless if it is an old post. There is a lesson to be learned here for the new-to-motorcycle owner/rider.
    Read your owners manual. There really is some good info in there for the newbie. I would venture to guess that most of us in here has not leafed through theirs, myself included. But then again, most of those that have not, consider themselves experienced in such matters.
    No such thing as ride, ride and ride some more, without some maintenance. Might be as simple as lubing a chain, or adjusting a clutch cable. The more you ride & then put it away "wet", the sooner the heartbreak.
    Check your oil, dipstick. Common knowledge dictates that a new engine will use more oil than a one that has been broken in properly.
    Change your oil frequently. Our beloved Groms live at a pretty high RPM for most of its life. Treat it to a change of oil. Hey, it is only a quart...
    2018 Grom
    Seat Concepts / Opmid V2
    is "Working"
    Wicked_VFR's Avatar
    19169
    New Hampshire
    11,500
    117
    OP no longer owns a oil eating grom anymore probably LOL
    2017 Honda Grom SF
    [ Koso 4v 181 | Koso 34mm TB | Koso Cam | Koso Cam Chain Tensioner | 10hole Injector | Aracer RC1 W/ Wideband | Dinger Intake | Brembo P32s w/ VEE Rotors | Ohlins Suspension | GromFatherz Manual Tensioner, Headstuds, Speed Spacers, Cam Cover | Carbon Fiber Everything | ]
  1. help please, engine noise
    By gromtech in forum Grom How-To's and Guides
    Last Post: 01-11-2018, 07:08 PM
  2. Engine Light
    By Meemo in forum Grom Performance
    Last Post: 06-25-2016, 08:25 AM
  3. FS: Engine Sliders
    By YYZGROM in forum Parts for Sale / Wanted
    Last Post: 05-05-2015, 09:08 AM
  4. What engine oil?
    By Khauff in forum Grom Talk
    Last Post: 07-03-2014, 10:59 AM
  5. How do you break in a new engine?
    By Strokd_GE in forum Grom Talk
    Last Post: 06-07-2013, 02:37 PM
honda msx125 engine seizied
