White jizz in my oil, 35 total miles?? - Page 3
This is a discussion on White jizz in my oil, 35 total miles?? within the Grom Talk forums, part of the Honda Grom Forums category; Originally Posted by xxxstefxxx 6000 miles, still having sludge. all stock. the neutral light goes wicked from the sludge. also, a lot of crankcase pressure. ...
Results 21 to 22 of 22
Like Tree7Likes
Thread: White jizz in my oil, 35 total miles??
    777
    Quote Originally Posted by xxxstefxxx View Post
    6000 miles, still having sludge. all stock. the neutral light goes wicked from the sludge. also, a lot of crankcase pressure. need a comp. test. i guess its the 5 or 10 percent ethanol that turns into water, through the injector, through the rings into the oil. the nasty hole at the beginning of the rear muffler 2013/2015 model. spits out all that unburned crap, making the rear brake disc dirty, superb rear brake performance.
    I think you may have meant 600 miles?
    31450
    NorCal
    30
    I believe the white stuff is not foaming oil but foaming water mixed with oil. The temp does have to get up long enough to burn off the condensation that builds up in the crank case. When something that is hot cools off, it condenses the moisture in the air and collects in the crankcase until it's warmed up and burned off. If you don't run it long enough to vaporize the moisture it will continue to build. That's why it looks similar to what you see in a water cooled engine with a blown head gasket. The sludge is also mildly acidic so it's a bad idea to let it build up.
    2018 GROM
    Mods before break-in;
    Werkes Performance Exhaust
    Koso Air filter with inner snorkel removed
    Power Commander V
    14 tooth front sprocket
    Protaper bars and adapters
    CRG levers
    Bar end mirrors
    Fender Eliminator with sequential turn signals
    and flasher unit.
    NDCustomz Chain adjusters
  1. FS: OEM under cowl...white
    By deanball in forum Parts for Sale / Wanted
    Last Post: 03-11-2014, 07:25 AM
  2. Replies: 8
    Last Post: 10-28-2013, 03:28 AM
  3. FS: White Underbody Cowl
    By jeankysti in forum Parts for Sale / Wanted
    Last Post: 10-02-2013, 07:52 PM
  4. White plastics
    By deanball in forum Grom For Sale / Wanted
    Last Post: 09-20-2013, 06:29 AM
  5. White walls
    By banks619 in forum Off-Topic
    Last Post: 06-13-2013, 06:24 PM
grom oil white stuff
honda trail 70 milky oil
jizz
jizz oil
jizzjizz oil bathing
jizzoile
white jizz
you jizz oil
