White jizz in my oil, 35 total miles?? - Page 2
This is a discussion on White jizz in my oil, 35 total miles?? within the Grom Talk forums, part of the Honda Grom Forums category; Originally Posted by BanditX2 FXCLM5 nailed it, the Exact same thing happened with me. I was ready to head back to the Honda stealership and ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
Like Tree7Likes
Thread: White jizz in my oil, 35 total miles??
    is #teamblue #gromsolo
    BlueRidge's Avatar
    107
    Western NC
    9100
    1,549
    Quote Originally Posted by BanditX2 View Post
    FXCLM5 nailed it, the Exact same thing happened with me. I was ready to head back to the Honda stealership and have some words, but the grom forum came to the rescue with the right answer. My problem is that I've even got water dripping from the joint where the header pipe meets the exhaust can. never seen that before.
    i was cranking mine during winter every week or so and i noticed the same thing.. moisture leading from the joint in the header pipe and exhaust.. need more riding time less sitting in garage time..
    never seen jizz in my oil though.. lol..
    JB426's Avatar
    2551
    Mar 2014
    NM
    28
    Quote Originally Posted by GromGrom View Post
    All the more reason to leave earlier to work and to take the long route
    True.
    2276
    Feb 2014
    11
    I got jizz in my grom too. I changed the oil and try to ride and warm it up more often. most of my trips are very short so its a bit tough to manage. I usually smoke a cigarette after i start the engine to give it some time to warm up. will do another oil change soon when time allows just to get that jizz out.
    bigzipper's Avatar
    2972
    May 2014
    Oshawa ontario
    1000000
    22
    Could be assembly grease from the factory.
    "Pain is just weakness leaving the body"
    Pain is just weakness leaving the body.
    Current rides.
    2007 BMW GSA
    2010 Suzuki GSXR 1000
    Over 80 previous bikes.
    Platinum Supporting Member
    is They see me Gromin, they be
    hatin
    jmzd4's Avatar
    30
    NC
    2000+
    1,415
    damn fist posts and everything.
    I was wondering what the hell you are doing to your bike? you sick bastard
    rynosaur likes this.
    2008 GET Ruckus 12k+ miles
    2014 "AKAONI"https://www.hondagrom.net/forums/27-g...16-akaoni.html
    CarolinaCoN '09, '10, '11, '12, '13, & '14
    2696
    Apr 2014
    Central MD
    24
    ive also had the same problem at the pipe/can interface.. good to know... thanks... and to think i only read this thread to find out where the jizz came from.
    xxxstefxxx's Avatar
    16361
    Feb 2017
    Belgium oostende
    82
    300 miles , still jizz , i bet 10w 40 is too much , must be 10w 30 i gess to get the antifoaming to work better. or it is grease , who knows ,whe will see . can it be , to much oil , too much compression in the crack case , and you get water of the decompression. dont know yet . will see soon
    xxxstefxxx's Avatar
    16361
    Feb 2017
    Belgium oostende
    82
    6000 miles, still having sludge. all stock. the neutral light goes wicked from the sludge. also, a lot of crankcase pressure. need a comp. test. i guess its the 5 or 10 percent ethanol that turns into water, through the injector, through the rings into the oil. the nasty hole at the beginning of the rear muffler 2013/2015 model. spits out all that unburned crap, making the rear brake disc dirty, superb rear brake performance.
    7548
    Sydney Australia
    19
    That was me.
    What can I say other than ‘I love groms’
    2016 SF Grom (Australia)
    Takegawa high flow oil pump
    Kitaco clutch springs (3/6)
    Takegawa 3rd bearing
    Kitaco clutch plate
    HEL braided lines front and rear
    Ohlins fork kit
    YSS Stage 2 rear shock
    Protaper honda mini bars
    Takegawa high flow air filter (un-installed, too noisy)
    Moriwaki Megaphone
    Clear indicator covers and switchback indicators with led rear
    MML monster eye conversion
    Kitaco solid bar mounts
    Fender eliminator
    Shorty mirrors
    14T front sprocket
    Speedo healer
    7,627
    Quote Originally Posted by blackonblacklikeatimtam View Post
    That was me.
    Don't worry about the white stuff just as long you don't see a lot of metal flakes in your oil you be ok and ride it like you stole it
  1. FS: OEM under cowl...white
    By deanball in forum Parts for Sale / Wanted
    Last Post: 03-11-2014, 07:25 AM
  2. Replies: 8
    Last Post: 10-28-2013, 03:28 AM
  3. FS: White Underbody Cowl
    By jeankysti in forum Parts for Sale / Wanted
    Last Post: 10-02-2013, 07:52 PM
  4. White plastics
    By deanball in forum Grom For Sale / Wanted
    Last Post: 09-20-2013, 06:29 AM
  5. White walls
    By banks619 in forum Off-Topic
    Last Post: 06-13-2013, 06:24 PM
grom oil white stuff
honda trail 70 milky oil
jizz
jizz oil
jizzjizz oil bathing
jizzoile
white jizz
you jizz oil
