How much oil do you guys run?? - Page 2
This is a discussion on How much oil do you guys run?? within the Grom Talk forums, part of the Honda Grom Forums category; Originally Posted by Paultergeist I have the Kitaco clutch cover -- no oil cooler. My engine is otherwise stock. I just pour an entire quart ...
Results 11 to 15 of 15
Thread: How much oil do you guys run??
    MSX UD ITA's Avatar
    5772
    1500 km
    780
    I have the Kitaco clutch cover -- no oil cooler. My engine is otherwise stock. I just pour an entire quart (.946 liters) bottle into the crankcase at every oil change. Based on the little glass window on the Kitaco clutch cover, that amount of oil appears to be a little bit high, but I surmise that I am still within tolerances. I have had no issues with just dumping the entire quart in with every oil change.
    oil change with or w/o filter ?
    I'm confused, I put 1.2 to have a decent level.. especially for cold starts.... (0° c)
    seriously.. at cold starts I saw oil disappear from oil level window.. even with right inclined bike.. maybe I'm too much apprehensive
    makg's Avatar
    26273
    Dec 2017
    52
    Well then, hold on to that warm fuzzy feeling, because unless you flush and drain the crankcase (which would be totally un- necessary), there is always a little bit of the “old” oil left in the engine during an oil change. This volume of residual oil is diluted with each oil change, and is generally considered to be of no significance.
    but if you are using an external oil cooler and you were really worried about it, you can always just disconnect one hose from the lower fitting on the oil cooler, and just let the oil drain out. No biggie either way.
    I didn’t realize how little capacity they had, the Kitaco cooler is 75cc which is about 0.08 quarts, which means that less than 10 percent is retained. But still, that’s more substantial than oil clinging to my crank case. You bet I’ll hold on to my warm fuzzy feeling because I don’t have a cooler to worry about.
    Quote Originally Posted by MSX UD ITA View Post
    With the bikes I’ve owned, the sight glass becomes relatively worthless after it’s cranked and the pump runs, draining the sump.
    847
    Either way....but most of the time, I replace the small cartridge oil filter.
    847
    Quote Originally Posted by makg View Post
    This has been my experience as well; the sight glass window is ~accurate with the bike engine not running, the engine turned off long enough for the oil to settle in the sump, and the bike being held level. The same is true for using the (stock) dipstick.
    2,353
    Correct. Dipstick / sightglass readings are rather useless with the bike running or shortly there after unless specified in the manual (IE a dry sump system)
    I think the grom manual states idle the bike for a few minutes, shut it off wait 1 or 2 minutes then take a reading.
  1. What weight oil do you guys run?
    By nd4spdbh in forum Grom Talk
    Last Post: 02-12-2016, 03:49 PM
  2. Hi guys...
    By Converse in forum Introductions
    Last Post: 01-21-2015, 08:59 AM
  3. Replies: 7
    Last Post: 05-02-2014, 01:03 PM
  4. What oil to run?
    By Black92hawk in forum Grom Performance
    Last Post: 12-17-2013, 03:05 PM
honda grom how many liters of oil
honda grom oil capacity
how much oil 2014 honda grom
how much oil does 2017 grom take
how much oil does a honda grom take
how much oil goes in to a grom
how much oul does a honda grom take
how to add for low oil grom
