ND4's Bulletproof clutch mod - Page 4
This is a discussion on ND4's Bulletproof clutch mod within the Grom Talk forums, part of the Honda Grom Forums category; Well FYI to everyone the 3 hole plate from the sic shop won't work without getting it machined as the lips are too concaved for ...
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 35 of 35
Like Tree7Likes
Thread: ND4's Bulletproof clutch mod
  1. #31
    26057
    Dec 2017
    37
    Well FYI to everyone the 3 hole plate from the sic shop won't work without getting it machined as the lips are too concaved for the bolts to go in straight and they won't sit flat.
    I ordered the chimera plate, which is supposed to come with 6 holes already in it so we shall see.
  2. #32
    is doing grom things
    phillybuilt's Avatar
    20097
    CT
    360
    Quote Originally Posted by Np214 View Post
    Yep... that is what mine looked like when it showed up... oh well.
    Lesson learned for everyone else.
    Sent from my HTC One A9 using Tapatalk
  3. #33
    2,347
    ah dang, sorry guys!
  5. #34
    is a centrifugal oil filter
    665
    If you have billet 3 hole plate you'll be just fine.
    I understand why ND is doing it if he has a 6 hole plate to start with, it's nice, I'm convinced it is bulletproof and probably the best solution, I'm just not sure you NEED 6 holes AND billet.
    My stock 3 hole plate has been doing fine on my 4 valve setup with Kitaco springs.
    The Takegawa slipper cluth plate is cast but has 6 holes to begin with and is relatively cheap at 30-35$.
    Part number 22361-K26-T01
  6. #35
    26057
    Dec 2017
    37
    Quote Originally Posted by David View Post
    I'm sure it's fine the way it is. Just one of those things If I'm putting a billet cover in might as well do it. It's too cold and snowy to ride here anyway so I don't mind waiting.
  1. How to: ND4's fork upgrade mod.... 15 bucks, worlds better!
    By nd4spdbh in forum Grom How-To's and Guides
    Last Post: 08-17-2019, 07:45 AM
  2. [Build] ND4's Function over Form Build
    By nd4spdbh in forum Grom Builds
    Last Post: 10-26-2018, 04:31 PM
  3. [How-To Video] ND4's Fork Mod - VIDEO!!
    By jzehren11 in forum Grom How-To's and Guides
    Last Post: 03-03-2017, 03:57 PM
  4. Kitaco Clutch Cover and air box mod
    By dubnasty216 in forum Grom Talk
    Last Post: 07-23-2016, 04:05 PM
  5. Replies: 0
    Last Post: 09-08-2014, 12:24 PM
