ND4's Bulletproof clutch mod - Page 3
This is a discussion on ND4's Bulletproof clutch mod within the Grom Talk forums, part of the Honda Grom Forums category; Originally Posted by nd4spdbh I actually tapped mine on the bike as it holds the pressure plate very well (had to take it off to ...
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 35
Like Tree7Likes
Thread: ND4's Bulletproof clutch mod
    26057
    Dec 2017
    37
    I actually tapped mine on the bike as it holds the pressure plate very well (had to take it off to clean the tapping flakes) You gotta be slow and methodic with a tap. 1/4 turn of cutting, back off a full turn. fully pulled the tap out of the holes probably 4x per hole to clean the tap and re lube with some oil.
    If i had something to keep the clutch from spinning it probably would have been fine. Oh well, a new one was only $17 so not too bad of a mistake.
    2,353
    Quote Originally Posted by Np214 View Post
    I forget what side the pressure plate was on. But you can either pop a quarter in the primary gear to hold things from spinning, or put the trans in gear (4th) and use the rear break
    is doing grom things
    phillybuilt's Avatar
    20097
    CT
    366
    Placed my order for the clutch plate and 6 finbro springs today. Left a note asking for the 6 hole version, they sent me back an email saying that the 6 hole ones are on back order... still waiting for a reply on timeframe.
    Good thing it's winter... and riding is temporarily on hold.
    Sent from my HTC One A9 using Tapatalk
    2,353
    Quote Originally Posted by phillybuilt View Post
    I feel bad for you guys and winter..... I was out on "The Snake" on my grom xmas day, then on the big bike (honda 919) a few days later in beautiful 75* weather
    20097
    CT
    366
    I just got an email back, West Coast Raceworks is who makes the 6 hole version, they do not know when they are making more. So I'm just going to take the 3 hole version and put it on a drill press and make it a 6 hole.
    The sic shop is always good to deal with. They had the best price on this and the customer service was great.
    This was the weather last week...
    2,353
    those temperatures are missing digits. FML THATS COOOLLLLLD!
    20097
    CT
    366
    We were in single digits for a few days, overnight negative temperatures. It's rough.
    Anyways, I took my Grom apart today, to tap the other 3 holes. I found that after fully tapping them (normal tap not a bottom tap) and I am going to need slightly shorter bolts. Only 3-4 mm difference, haven't measured exactly. They all stopped at the same spot.
    They did tap very easily on the bike. Held the brake and left it in gear, worked fine. The clutch plate and springs shipped out today. Quick date with the drill press and we'll be all set.
    Every time I look at the oil spinner, I remember that I really need a Kitaco cover...
    26057
    Dec 2017
    37
    I'm going to do this as well, seems simple enough.
    2,353
    I tapped all the way through the holes without issue. And grabbed a metric bolt the same length as the stockers n didnt have an issue.
    As far as the kitaco cover, just take the stock spinner to a buddy and have him turn it down for a 6 pack of beer. I had a buddy owe me a favor and he has a lathe at his place. 10 min later and 1.2Lbs off the outer part of the spinner! cost = free
    is adventuring one bike at a
    time.
    AzizaVFR's Avatar
    7236
    Red Rock, AZ
    149
    Yes, it is easy to cut the oil spinner reducing the mass. The chips do carry quite a bit of heat with a decent cut.
    2015 Grom (track/training bike)
    2016 BMW R1200GS (Daddy Bike)
    2018 BMW G310R (Daughter's new ride)
    "Six bikes are our limit." -Unicorn Wife
  1. How to: ND4's fork upgrade mod.... 15 bucks, worlds better!
    By nd4spdbh in forum Grom How-To's and Guides
    Last Post: 08-17-2019, 07:45 AM
  2. [Build] ND4's Function over Form Build
    By nd4spdbh in forum Grom Builds
    Last Post: 10-26-2018, 04:31 PM
  3. [How-To Video] ND4's Fork Mod - VIDEO!!
    By jzehren11 in forum Grom How-To's and Guides
    Last Post: 03-03-2017, 03:57 PM
  4. Kitaco Clutch Cover and air box mod
    By dubnasty216 in forum Grom Talk
    Last Post: 07-23-2016, 04:05 PM
  5. Replies: 0
    Last Post: 09-08-2014, 12:24 PM
