Stunt Build/More Power Questions - Page 20
This is a discussion on Stunt Build/More Power Questions within the Grom Talk forums, part of the Honda Grom Forums category; Bad bish with a little more of a blacked out look. Z&Z rearsets and smoked blinkers/black boomerangs are the only cosmetic changes. Oh yeah, and ...
Page 20 of 20 FirstFirst ... 10 18 19 20
Results 191 to 200 of 200
Like Tree73Likes
Thread: Stunt Build/More Power Questions
  1. #191
    is doing grom things
    phillybuilt's Avatar
    20097
    CT
    334
    Bad bish with a little more of a blacked out look. Z&Z rearsets and smoked blinkers/black boomerangs are the only cosmetic changes. Oh yeah, and a stock clutch lever was put back on.
    Waiting for the cam sprocket, roller in the cylinder, and hardware to arrive, then it's ready to fire up.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  2. #192
    594
    Stunt Build/More Power Questions-hindle-muffler-replacement.jpg I'm still running the Hindle header, but took a chance on this fake yoshimura muffler off ebay and hit a home run. It's so much quieter, the quality seems very good for $55, and I didn't lose any power.
    phillybuilt likes this.
  3. #193
    20097
    CT
    334
Name:	Hindle muffler replacement.JPG
ID:	80710 I'm still running the Hindle header, but took a chance on this fake yoshimura muffler off ebay and hit a home run. It's so much quieter, the quality seems very good for $55, and I didn't lose any power.
    Link me! I like quiet. May go this route also
  5. #194
    7,820
    Quote Originally Posted by phillybuilt View Post
    check these out
    https://www.aliexpress.com/item/Univ...E&gclsrc=aw.ds
  6. #195
    594
    https://ebay.us/gIK74v
    I just had to weld one spring loop (included) to the muffler to match the one on the Hindle header. Then find a super short exhaust spring from the hardware store. Then I made a muffler bracket. Not to hard.
    The slip-on muffler fit is just a hair bit loose onto the header, but it seems fine to me. I can't detect any leaks, rattles, or vibrations.
  7. #196
    20097
    CT
    334
    The rest of the parts showed up today. Had to charge the battery before I could start it, and setup the aracer program on my new phone. Started right up, no oil leaks, no smoking, etc. Then I started getting on it, and I got a few mid RPM hiccups. Cutting in and out like it was misfiring for a brief moment. Logged it through aracer and I'm getting a wicked RPM spike. Going to try to clean up all the connections and if that doesn't work out, a new stator will be on the way.
    There's a brand new Honda flywheel in there also. Mine slipped and fell off the toolbox denting it pretty hard. My woodruff key was perfectly fine and I took the time to line it up. It doesn't happen all the time either, like if the key had slipped. The RPM signal seems to get more inconsistent the higher it goes, at least in this graph.
  8. #197
    20097
    CT
    334
    Cleaned connections, no luck. This time, a few hard pulls later, and another 335 code for crankshaft position sensor... so new stator on the way.
    So close, yet so far. I did do a mean rollie with it even though it didn't feel like full power. Thing feels like a big heavy Cadillac compared to my girl's Z125.
    We'll be back out there killin the streets yet again, very very soon.
  9. #198
    594
    15,368rpm?
  10. #199
    20097
    CT
    334
    15,368rpm?
    Wonky pickup... should be fixed next week when the new stator shows up.
    You go 4 valve yet??
  11. #200
    594
    Its coming.
  1. Stunt/ Daily Driver build
    By dubnasty216 in forum Grom Talk
    Last Post: 01-25-2017, 11:12 AM
  2. Hawaii stunt bike build
    By HooligansCustom in forum Grom Builds
    Last Post: 03-06-2016, 11:33 AM
  3. Stunt bike build questions....
    By Not2brekinwit in forum Grom Talk
    Last Post: 08-03-2015, 01:09 PM
  4. Power commander questions
    By gromrevver in forum Grom Performance
    Last Post: 10-10-2014, 10:50 PM
  5. Running lean/power commander questions
    By Town Drunk in forum Grom Talk
    Last Post: 05-26-2014, 08:19 AM
clutch grom big bore
grom stunt bike top speed
grom stunt gearing
kawasaki z125 stunt bike
