Z125 High Idle for Stunt anybody?
This is a discussion on Z125 High Idle for Stunt anybody? within the Grom Talk forums, part of the Honda Grom Forums category; Since a lot of grom owners have Z125 as well, has anybody had any luck cranking up the idle on the Z125? Running a Honda ...
Results 1 to 5 of 5
Thread: Z125 High Idle for Stunt anybody?
    1839
    Nov 2013
    138
    Running a Honda idle adjuster and as soon as the idle was turned up, the engine light came on and it will bog badly with high idle.
    The Grom had to overcome this IIRC, so has anybody found a workaround?
    Sent from my SM-N915V using Tapatalk
    ...::: zeus-armor.com :::...
    2,332
    real easy to turn the idle up on the grom with the throttle plate stop screw on the TB. dunno about the Z
    1839
    Nov 2013
    138
    Turning the idle up is the easy part... Getting the ECU not to throw a fit is the complicated part
    2,332
    ECU shouldnt have an issue.
    Get the bike idiling properly at 1400ish rpms, reset the ecu, reset the TP.
    THEN use the throttle stop adjuster to up your idle, the ECU knows no different between that holding the throttle more open or the actual throttle itself.
    1839
    Nov 2013
    138
    What is the ECU reset procedure for the Z125? Nobody seems to know
  1. Grom Issue : High Idle... Looking for advice
    By mabruke in forum Grom Talk
    Last Post: 07-06-2017, 12:46 AM
  2. Intermittent high idle
    By Devildogduke in forum Grom Talk
    Last Post: 02-27-2017, 11:19 AM
  3. High Idle Problem
    By PhunkyCold in forum Grom Talk
    Last Post: 10-01-2016, 06:40 PM
  4. High idle in gear? Fixit question
    By WAGrom in forum Grom Talk
    Last Post: 09-29-2015, 02:34 PM
  5. High idle pcv
    By gnarventures in forum Grom Performance
    Last Post: 05-04-2014, 09:04 PM
grom or z125 stunt
z125
z125 problems after adjusting idle
