Clutch cover bolt torque specs? Foot lbs?
This is a discussion on Clutch cover bolt torque specs? Foot lbs? within the Grom Talk forums, part of the Honda Grom Forums category; Whats the clutch covers bolt torque specs? Isnt it like 7 foot lbs or something? thanks...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Clutch cover bolt torque specs? Foot lbs?
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    682
    thanks
    is Still trying to find the Flux
    capacitor in this thing
    jtirwin27's Avatar
    7026
    Feb 2016
    Northwest Atlanta, GA
    several
    199
    7 for clutch springs, 9 for cover
    "Faster, Faster, until the thrill of speed overcomes the fear of death"
    2,316
    Quote Originally Posted by jtirwin27 View Post
    clutch pressure plate are 9 ftlbs.
    I have scoured the service manual for the torque specs for the right side case bolts and that figure it no where to be found. 9-10 ftlbs seems to be adaquate however for the 10 or so bolts that hold the side cover on.
    Clutch cover bolt torque specs? Foot lbs?-cover.png Clutch cover bolt torque specs? Foot lbs?-clutch.png
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    682
    Ok cool thanks...damn now I'm gonna have to go buy a new torque wrench mines bigger I think it starts at like 25-30lbs and up...they gotta make one starts at like 10lbs right?
    2,124
    Quote Originally Posted by Ronbang View Post
    Ive got a... i forget the brand, but it goes from 0-28 Nm (maybe not 0, but near 0). (it also is in Nm and In-Lb). Of course, i have a larger one too for big stuff, 25-100 ft-lb or so.
    TheMajekalBum's Avatar
    6538
    Oct 2015
    Longmont, Co
    291
    Personally I wouldn't torque the side cover more than 10nm(7.3ftlbs and about standard spec for its size). 10ftlbs is 13.6nm and I've seen(ASE auto tech) holes and hardware (this 8mm metric size)become stripped or partly stripped by slight (yes, a few Newton meters will do it) over torquing. You'd be surprised at how little torque is needed to seal a sealing surface.
    2,316
    OP you need an inch pound torque wrench. Harbor freight has a 1/4in drive inch pound guy. Take any desired ftlb torque and multiply it by 12 to get inch pounds.
    And noted, so 7-8 ftlbs for the side case bolts would be better than 10.
    2,124
    or divide the in-lb by 12 to get ft-lb!
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    682
    Cause i cant find one with under 10lbs and that ones like $35
    you got a link to the one from harbor freight
    2,124
    Search results for: 'torque wrench'
    the 1/4" drive are 20-200 in-lb, the 3/8" drive are 5-80 ft-lb (60-960 in-lb).
  1. OEM Clutch cover, spinner, oil pump, clutch springs
    By Pigman in forum Parts for Sale / Wanted
    Last Post: 04-27-2016, 10:42 AM
  2. Just broke bolt tightening crankcase cover on after oil change!!!!
    By kobebryantla in forum Grom How-To's and Guides
    Last Post: 11-30-2015, 12:31 PM
  3. HELP! Broke bolt installing clutch plate
    By Jaygrom in forum Grom How-To's and Guides
    Last Post: 11-22-2015, 09:02 AM
  4. Replies: 7
    Last Post: 10-09-2015, 09:40 AM
  5. bolt torque
    By mattallac in forum Grom How-To's and Guides
    Last Post: 03-28-2015, 08:23 PM
1986 honda cb450sc clutch cover torque
2006 honda cbr1000rr engine torque specs
clutch cover bolt torque
clutch housing and clutch plate set for honda nsr 150 rr
crf250r clutch pressure plate torque setting
grom oil spinnder bolt torque
honda generator cover screw nm torque
housing clutch and plate clutch set honda nsr 150 rr
