DYNO JET POWER VISION 3 (PV3) for the HONDA GROM FULL CONTROL REFLASH PV3-16-01 - Page 17
This is a discussion on DYNO JET POWER VISION 3 (PV3) for the HONDA GROM FULL CONTROL REFLASH PV3-16-01 within the HardRacing Performance forums, part of the Vendors category; Originally Posted by BUCKNUT Kinda got Rick-Rolled on that one. I'm not sure it was on purpose because this thread isn't called "Understanding Narrow Band ...
Page 17 of 19 FirstFirst ... 7 15 16 17 18 19 LastLast
Results 161 to 170 of 190
Like Tree58Likes
Thread: DYNO JET POWER VISION 3 (PV3) for the HONDA GROM FULL CONTROL REFLASH PV3-16-01
  1. #161
    593
    Quote Originally Posted by BUCKNUT View Post
    I'm not sure it was on purpose because this thread isn't called "Understanding Narrow Band o2 Sensor".
  2. #162
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    Charlotte, NC OHLINS_MASTER_DEALER
    3,939
    That link brings me right back to this thread.
    air_fuel_ratio_sensor
    HardRacing.com - 704-799-2192
    See our complete >> GROM PARTS CATALOG << >> MONKEY PARTS CATALOG<<
    Check out our Youtube Channel for Lots of Great Parts Installation Videos >> YOUTUBE CHANNEL<<
    Ohlins Premier Dealer, Great Prices, Tech.Support, Full Staff of Sales Reps, Fast WORLD WIDE Shipping,
    Large Inventory and Excellent Customer Service.
    Celebrating our 20th year in business
  3. #163
    is Monkey water skiing, so much
    rain here!
    BUCKNUT's Avatar
    1725
    Nov 2013
    The North Coast OHIO
    360
    I know it wasn't on purpose. Hard Racing wouldn't do that.
    2014 Black Grom
    2019 Red Monkey
  5. #164
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    3,939
    The last 3 days of posts on this thread have been all about o2 sensor and understanding the difference between the Narrow band and wide band.
    So the link is pretty relevant to the current topic at hand . ;-)
  6. #165
    593
    Quote Originally Posted by HardRacing View Post
    It is and I appreciate it. I just didn't know what was going on with the first link that you posted that just took me right back to this thread. LOL
  7. #166
    654
    I thought they were being funny.
  8. #167
    593
    Does anybody have any updates on the inexcusable issue that the PV3 reads Engine Oil Temperature incorrectly?
    I shouldn't have to spend another $100 to have correct temperature readings on a tuning device! You'd think this would be a simple firmware update.
  9. #168
    2205
    Orlando, Florida
    168
    In my experience, the PV3 EOT were closer to my digital thermometer readings than my Koso DB03-R. The PV3 is off by ~9% while the DB03-R is ~20%. Also, the PV3 is interpreting the ECU data and not just the signal from the temperature sensor.
    mikochu
    2018 Honda Grom (Matte Gray)
    Suspension:
  10. #169
    593
    Quote Originally Posted by mikochu View Post
    Thanks for the info. I still think Dynojet could create their own software curve to make the temperature more accurate.
    In this case, at what EOT on the PV3 should I start getting alarmed?
  11. #170
    2205
    Orlando, Florida
    168
    Just a heads-up on Engine Oil Temp output on the PV3 compared to other gauges...
    I installed a Koso DB-03R on my 2018 Grom and recorded some data. Overall, it looks like the DB-03R output temp is ~8.5% lower than the PV3, and the PV3 output is ~9.2% than ambient. The DB-03R is potentially ~20% off. However, the Koso updates the temp output more often than the PV3/ECU.
    Either way, I think it's all relative and the PV3-flashed ECU is using its internal information in its calibrations.
    If you read Dyno(jet) Dan's posts, he states the PV3 EOT values mirror the factory scan tool from Honda.
    As for monitoring EOT on the PV3, my temps hovered around 230-240°F on my DHM 186 before switching to a CPR7EA-9 sparkplug. That's around 210-220°F on simpler gauges. I've also seen as high as 270°F before engine shut down on the stock jug/piston.
    mikochu
    Suspension:
  1. Replies: 1
    Last Post: 06-19-2017, 05:21 PM
  2. Replies: 21
    Last Post: 08-30-2016, 07:04 PM
  3. Replies: 3
    Last Post: 09-04-2015, 07:44 AM
  4. THE *NEW* Thursday night rides... 01/16/14
    By minkus in forum West / West Coast Grom Owners
    Last Post: 02-13-2015, 01:04 PM
  5. Replies: 133
    Last Post: 06-22-2014, 08:30 AM
dynojet power vision 3 grom
dynojet pv3 tuning
grom powervision tunes
power commander pv3
power vision 3 grom
power vision 3 honda grom
power vision honda msx
pv3-16-01
Tags for this Thread
