How to: ND4's fork upgrade mod.... 15 bucks, worlds better! - Page 36
This is a discussion on How to: ND4's fork upgrade mod.... 15 bucks, worlds better! within the Grom How-To's and Guides forums, part of the Honda Grom Forums category; Originally Posted by ia02 I saw that! Much appreciated. The mechanics of it make sense. So why do you think it ends up "firmer? feeling? ...
Page 36 of 36 FirstFirst ... 26 34 35 36
Results 351 to 360 of 360
Like Tree86Likes
Thread: How to: ND4's fork upgrade mod.... 15 bucks, worlds better!
  1. #351
    2,345
    Quote Originally Posted by ia02 View Post
    So why do you think it ends up "firmer? feeling? If it's not preload or spring rate, is it additional compression dampening being caused by the longer stroke?
    Firmer because you are compressing the main spring more at the end of the stroke + the addition of thicker oil to make the shim stack create more dampening.
    Similar in concept to preload, but in this form, its actually more proper because like stated, you increase fork travel (on the OG grom forks) by 25% which puts the stock sag with a normal 150-160lb rider in a more adequate zone (the fork sags just as much but you have another inch of travel before bottoming out).
  2. #352
    30520
    Dec 2018
    14
    I see. The spring is "firmer" feeling at the bottom of the stroke because we hit the bump stop and inch of travel later. The stock setup bottoms out on the bump stop way before the spring can provide that support, especially for a heavy rider. This makes way more sense.
    With all this in mind I do think this is worth trying to cobble together something more legit than the current proposed solution for the SF grom. I am going to see what I can come up with.
    THANK YOU for the explanation.
  3. #353
    2,345
    No problems! glad my explanation helped!
  5. #354
    Kaw'ee's Avatar
    30872
    Feb 2019
    Just got a e-mail to come check out your ND4 mod because i just did one for the Z125 and posted it on our forum.
    I read all 36 pages and now know what I'm in for ... Lol
    Nice thinkin man ...
  6. #355
    30990
    1
    Hello Do you know if this mod will work on the 2019 groms?
  7. #356
    is Monkey water skiing, so much
    rain here!
    BUCKNUT's Avatar
    1725
    Nov 2013
    The North Coast OHIO
    369
    Quote Originally Posted by superdappa View Post
    Please read the very first post in this thread. If you do a search there is a thread for the second generation Grom.
    2014 Black Grom
    2019 Red Monkey
  8. #357
    is MKEthunderknuckle
    5564
    Jun 2015
    Milwakee, WI
    88
    @nd4spdbh thanks for this tutorial. Just did this mod on my 15 OG, and it made a nice improvement to both ride quality and handling. I like how itís a bit less twitchy with the added trail.
    I didnít change the fork oil and itís still plenty firm for me. On a side note, itís quite spectacular the amount of stiction in these forks. LOL It felt like it got worse after this mod, but thatís probably because I have a lot more usable stroke and Iím no longer sagged through 60% of it.
    Quick tip for anyone attempting this: I suspended the front by hanging from the lower triples until the tire was barely above the floor. Once the 36mm fork caps are completely loose, I lifted the front wheel slightly (by hand) and slid a 2x4 under the tire. This exposed just enough of the damper rod out of the top of the forks to get some vice grips on for loosening the screws. Do what you need to create the new stack up top, retorque the little screws, and carefully remove 2x4 and lower the wheel back down to thread fork caps back in.
  9. #358
    631
    Quote Originally Posted by BUCKNUT View Post
    Which one are you talking about? I've seen a couple of different ones.
  10. #359
    5564
    Jun 2015
    Milwakee, WI
    88
    I think bucknutís reply was in response to the inquiry from @superdappa in regards to this mod on 2019 models.
    The first post in this thread states:
    NOTE: This does not work on the 2nd gen groms as they have different fork caps.
  11. #360
    631
    Quote Originally Posted by MKE GROMLIN View Post
    Sorry, I wasn't clear. Which SF mod was he talking about? I've seen at least two - changing oil and the other is a preload mod.
  1. ABS upgrade
    By Vampiere in forum Grom Talk
    Last Post: 03-08-2018, 12:03 PM
  2. Replies: 1
    Last Post: 10-13-2014, 07:24 PM
  3. Honda Grom speedo Healer 70 bucks on ebay
    By Limp1144 in forum Grom Performance
    Last Post: 08-31-2014, 06:48 PM
  4. I have $600 bucks burning a hole
    By TrukstopCale in forum Grom Performance
    Last Post: 04-16-2014, 05:26 PM
  5. Replies: 6
    Last Post: 11-07-2013, 06:47 PM
fork mod
grom fork mod
grom fork upgrade
honda grom fork mod
honda grom fork upgrade
honda grom forks
honda grom front fork mod
nd4s fork mod
