5 Speed Transmission - Page 2
This is a discussion on 5 Speed Transmission within the Grom Reviews, Rides and Impressions forums, part of the Honda Grom Forums category; Originally Posted by SHPL00P This is something I'd like to know myself, all I've really seen mentioned is like you mention, thinner=weaker gears. Fingers crossed ...
Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 44
Like Tree10Likes
Thread: 5 Speed Transmission
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    Quote Originally Posted by SHPL00P View Post
    This is something I'd like to know myself, all I've really seen mentioned is like you mention, thinner=weaker gears. Fingers crossed others have had good luck, but with a finbro 235 I don't think this will ever be a viable option for me
    Have seen a monkey forum where a guy broke 2 teeeth on 2nd and another one saying they were bump starting
    Both engines were the 138 dohc desmos...so high compression..others saying kickstart can break it...so Wondering if anyone has experience here... Ill look at gsx post soon. The tourist option offers 0.8 final drive be good for 80 mph on stock sprocket
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    Quote Originally Posted by David View Post
    Quote Originally Posted by Old Goat Ninja View Post
    If you have a big bore, yeah this should be achievable.
    I don't see how, 75mph is one thing, doing it at 6500rpm is another. GearingCommander says you'd need to run 19/30 sprocket combo which I don't think exists and even if it did it I don't think it would fit. Plus you'd need monster torque / power. It won't happen until someone comes out with a 400cc bbk
    Please see tourist option on the attachment.. 0.8 final drive yes sprocket would have to be changed with it but not as extreme as 19:30 i wouldnt have thought
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    I forget my maths, but 75mph requires ~16 hp (guessing).
    15hp = tq*6500/5252 => tq = 12.12 ft-lb. if I recall correctly, that’s about the max torque that the Koso 4v was making at roughly 8300 rpm. Since it was max, that means there was a lower torque than than, so prolly around 8-10, so its probably not going to happen. Maybe a 235 4v could do it.
    Looking at getting NEO kit in new year
    GROM_MSX likes this.
    2,132
    Quote Originally Posted by Waz-r View Post
    Ill check when I get home tonight. Do they have dyno sheets posted? if so, link?
    4112
    Oct 2014
    Southeast GA
    1,458
    Yeah even with 17/32 gearing and 140 rear tire 75mph is somewhere close to 8000rpm in 4th on stock trans ratio. That's with a 4v engine, don't think you'll be able to get gearing that tall or the power to pull it with engines available now.
    Old Goat Ninja and David like this.
    2,132
    In a tucked position, conservative estimate, 16 hp for 75 mph.
    Sitting up, average or so sized (not your weight, your overall size), closer to 20 hp. And thats with 0 wind.
    Koso 4v is peak torque of ~12.5 ft-lb at ~8k rpm (per their graphs). Not a chance in hell youre hitting 75 at 6500rpm.
    excel spreadsheet if anyone wants to try and mess around with it.
    https://www.dropbox.com/s/wtgnbdpn35...ower.xlsx?dl=0
    I highlighted the parameters you can change, as well as some notes to the right.
    info on C_d. https://en.wikipedia.org/wiki/Drag_coefficient
    TONS on motorcycle drag: http://www.schultzengineering.us/aero.htm
    Although, engineeringtool box gives it a 1.8, which i think is really high. http://www.engineeringtoolbox.com/dr...ent-d_627.html
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    NEO kit has "conservative" dyno sheet showing 19 HP
    I love my grom
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    ok so I think I get it now.. the speed could be achieved at 6500 however its more to do with the torque produced.. 19HP can get you to that speed easy enough in full tuck maybe even superman position however to do it sitting up the torque required will have to be much more than stock.
    I love my grom
    keit29's Avatar
    6117
    Aug 2015
    Columbus OH
    291
    Link? their own or a 3rd party? I don't think it makes 19hp at the stock rev limit, but would love to be proven wrong. I'd bet closer to 17.
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    I love my grom
  1. 5 speed transmission
    By Chad in forum Grom Talk
    Last Post: 09-20-2019, 08:58 PM
  2. TRANSMISSION Noise.
    By Grom1202 in forum Grom Talk
    Last Post: 07-19-2016, 12:30 PM
  3. 5 speed transmission
    By jay851 in forum Grom Performance
    Last Post: 05-19-2016, 07:03 AM
  4. 5 speed transmission?
    By VinnyC. in forum Grom Talk
    Last Post: 01-29-2015, 04:09 AM
  5. FS: SP Takewaga 4 Speed Cross Transmission Gear Set BNIB
    By doomid in forum Parts for Sale / Wanted
    Last Post: 09-15-2014, 09:10 PM
15 35 sprocket combination for honda grom reviews
honda grom transmission
