Rizoma Accessories For The Grom - Page 3
This is a discussion on Rizoma Accessories For The Grom within the Motovation Accessories forums, part of the Vendors category; Rizoma harness is a 2 wire and stock is 3 wire. If you want to cut up your stock signals yes you could make a ...
Results 21 to 25 of 25
Like Tree6Likes
Thread: Rizoma Accessories For The Grom
    is trolololol
    Ferris's Avatar
    3750
    Aug 2014
    Salt Lake City, Utah
    248
    Rizoma harness is a 2 wire and stock is 3 wire. If you want to cut up your stock signals yes you could make a jumper harness from that but I like to keep my stock parts so if I sell it I can put it back to completely stock but that's just my personal preference.
    OEM 3 Pin plug "Front Signal,Brake Side"
    This is the one you'd want. He has another that converts it from 3 to 2 wire but I don't know if the running light feature would work with the signal.
    While riding this morning I saw a banana peel in the road and instinctively swerved to avoid it...thanks Mario Kart!
    Check out my build and give me your feedback. Thanks!
    https://www.hondagrom.net/forums/27-g...-my-build.html
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    682
    I know there's a thread on here about hooking them up.....so with that one how would I hook it up to the rizoma if there's three wires does one get capped off?
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    682
    I don't want the rizomas to be on while riding only want them to blink when I turn them on
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    682
    The three to two keeps the running light...that means the signal will be on while riding then blink when turned on correct...I don't want that...I want them off while riding and blink when turned on
    is trolololol
    Ferris's Avatar
    3750
    Aug 2014
    248
    You could either cap/tape off the running light wire or just de-pin that wire from the plug. Just make sure you know which is the positive/negative wire then get some connectors or solder the wires together. It's not hard. Just a little knowledge about wiring needed.
  1. Replies: 3
    Last Post: 07-27-2013, 12:48 PM
  2. Hondaline accessories
    By dirt diver in forum Introductions
    Last Post: 06-30-2013, 08:02 PM
  3. Not Your Normal Grom Accessories, But Useful!
    By 4Nines in forum Grom Gear and Accessories
    Last Post: 06-29-2013, 11:48 PM
  4. Accessories For GROM
    By echo in forum Grom Talk
    Last Post: 06-03-2013, 03:01 PM
  5. Accessories
    By Billy Beach in forum Grom Talk
    Last Post: 05-28-2013, 08:16 PM
honda grom mirrors
honda grom mirrors rizoma knockoff
honda grom rizoma
rizoma grom
rizoma honda grom parts
rizoma mirrors for grom
rizoma msx 125
rizoma msx125
