Dobeck Performance Stage 1 kits- Exhaust & Tuner Packages - Page 3
This is a discussion on Dobeck Performance Stage 1 kits- Exhaust & Tuner Packages within the Dobeck Performance forums, part of the Vendors category; Originally Posted by CiscoSanJose I'm sure some of you have read a couple of my posting about Takegawa 4v BBK kit grom that walked away ...
Results 21 to 29 of 29
Like Tree9Likes
Thread: Dobeck Performance Stage 1 kits- Exhaust & Tuner Packages
    5376
    May 2015
    Belgrade, Montana
    18
    I'm sure some of you have read a couple of my posting about Takegawa 4v BBK kit grom that walked away from my BrianS 170 BBK grom going up the Hills in San Francisco and this is the Grom above that is owned by JDracer, I say he has one of the fastest grom out right.
    Not sure if he had any luck with the 10 hole F/I that we got.
    Looking at his settings 12.2 and 12.5 my PCV-WB02 unit sees 12.6-13.6 with the best power pull when the reading shows 13.2-13.4 A/F
    An AFR of 12.2 may be a bit on the rich side, fuel economy might not be great. In the end choose what you feel makes your bike run the best for your riding style.
    Here is a quick video that goes over Air/Fuel Ratios and what characteristics you might see for different AFR values.
    -TuningHQ
    adamv's Avatar
    4850
    56
    Have you guys done any testing with a DCR cam? Curious as to what optimal AFRs would be
    5376
    May 2015
    Belgrade, Montana
    18
    Quote Originally Posted by adamv View Post
    Adamv,
    We will be testing the DCR cam and will have dyno information and settings available once testing is complete.
    -TuningHQ
    411
    Texas
    386
    Any updates for the setting/ ratios using different cams for stage one with stock bore? Was trying to tume mine today by winds kicked up to 25mph plus. There goes that.
    Thanks
    2014 MV Agusta Brutale 1090RR Pearl White
    87 Honda VFR 700 Pearl White
    88 Honda ZB 50 Takegawa 115 Kit 5 Speed
    03 Honda XR50 Kitaco 88cc Kit
    69 Mini Trail 50
    83 Blue ATC 70 w/Powroll 83cc Kit
    1976 Yamaha RD400C
    Toys are good
    7143
    Mar 2016
    I'm really interested in the AFR+ but am in the UK, does it work with the UK spec bike (stock apart from radiator hose mod, Takegawa filter and Arrow full system)? If so do you ship to the UK? Also does the AFR+ control both the open and closed loop like the PCV and WB2 combo does?
    5376
    May 2015
    Belgrade, Montana
    18
    Parksie,
    We do ship internationally. Send us an email to [email protected] and we will get you squared away.
    The AFR+ should work fine on your UK model Grom.
    Our AFR+ does control both the open loop and close loop stock fueling. Since the AFR+ auto-tunes in the mid range and full throttle, you will have a closed loop tune up throughout the entire RPM range.
    Let us know if you have any other questions.
    -TuningHQ
    is in Canada-Eh
    6145
    Aug 2015
    Medicine Hat, AB
    103
    I will be going with a fuel controller from Dobeck Proformance for my stage 1 mods! Can't wait, excited!
    5376
    May 2015
    Belgrade, Montana
    18
    New settings for the Grom with cams has been posted to the EJK and AFR+ website. The DCR cam was used in finding these settings. These settings will be a very good starting point for Grom owners running the other cams that are available.
    The DCR cam is available for purchase from Dobeck Performance. If you are pairing the DCR cam with Dobeck fuel solutions, give us a call and we will put a package together for you at a heavily discounted price.
    Dobeck Performance is a supporting vendor on this forum. Let us put a performance package together for you that includes your choice of an exhaust, a DP fuel solution and we can also provide you with a cam, intake, and even a big bore kit.
    Let us know what you want to put together and we can help you SAVE BIG!
    Thanks for supporting your Grom Supporting Vendor!
    -TuningHQ
    D.Snutts's Avatar
    5994
    Aug 2015
    Nampa Idaho
    7
    Quote Originally Posted by TuningHQ View Post
    -TuningHQ
    Im curious about the actual dyno performance/power curve. I'm thinking about purchasing the afr+. I've seen dyno sheets using your competitions tuners. The power curves seem to smooth out considerably with the addition of timing control. Does this really make much difference in real world applications?
  1. Increase Clutch Performance! EBC Full kits.
    By MNNTHBX in forum MNNTHBX
    Last Post: 05-08-2015, 09:56 AM
  2. Dobeck Performance AFR Plus
    By edze in forum Vendor Reviews / Links
    Last Post: 01-22-2015, 10:06 AM
  3. Dobeck performance
    By SAC in forum Vendor Reviews / Links
    Last Post: 08-13-2014, 05:45 PM
  4. Replies: 32
    Last Post: 01-25-2014, 09:23 AM
  5. Please welcome Dobeck Performance to HondaGrom.net
    By El Chorizo in forum Dobeck Performance
    Last Post: 10-05-2013, 11:11 PM
afr gen 4 honda grom two brothers
dobeck afr gen 4 aprilia rsv4
dobeck ejk horsepower gains
honda gorm stage one tuning
honda grom stage 1 tune up
honda grom tuning
