Wibbly's Grom winter project, how to do a 300 build right - Page 6
This is a discussion on Wibbly's Grom winter project, how to do a 300 build right within the Grom Builds forums, part of the Honda Grom Forums category; I ran a tank right down to see what the range is like. It does about 66mpg or 3.5L/100km. That's 100% in town riding with ...
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 57 of 57
Like Tree50Likes
Thread: Wibbly's Grom winter project, how to do a 300 build right
  1. #51
    712
    It does about 66mpg or 3.5L/100km. That's 100% in town riding with lots of heavy throttle. Not bad.
    The fuel light blinks when the tank is still 1/3 full. So if I go by the blinking light my range is around 60 miles or 100km, though I could push that to about 125 if I really had to.
  2. #52
    31754
    TB Adpater
    Would you share your throttle by adapter because i wan to do a 300 swap but i dont want to worry about tuning a af ecu, i would prefer to just put everything in and ride
  3. #53
    2205
    Orlando, Florida
    161
    Wibbly,
    After running the tank down, how many gallons was the fillup?
    mikochu
    2018 Honda Grom (Matte Gray)
    Suspension:
  5. #54
    712
    Quote Originally Posted by jpsqad View Post
    I would sell you one only if it will work in your application. If you use the chimera kit it will not work.
  6. #55
    712
    Quote Originally Posted by mikochu View Post
    Wibbly,
    105kms, 3.71 litres.
    Basically 1 gallon. There was still a fair bit of fuel in the tank but the low fuel indicator was flashing so I wasn't about to play chicken with it.
  7. #56
    31754
    And why is that? Is the area there to small for the adapter to fit?
  8. #57
    712
    the chimera kit puts the intake port very close to the frame.. (less than 50mm), there isn't room to build an adapter that will relocate the injector to that position. my design 100% won't work. i took a crack at drawing up a few different ones and it was just not happening simply. since i don't have a chimera kit i'd have to work with someone who did for the entire prototyping phase, and then i'd have to convince people to buy them. they would NOT be cheap, and from what i can tell most who do the chimera kit aren't looking to spend much money. so i just left that idea alone. too much for me to lose on it.
  1. 143cc BBK.. (winter Project)
    By Gpwett in forum Grom Performance
    Last Post: 09-13-2017, 08:52 AM
  2. Wibbly's Grom adventure
    By Wibbly in forum Grom Builds
    Last Post: 09-02-2016, 09:35 PM
  3. Honda cbr 300 ,Yamaha R3 or Kawasaki ninja 300
    By RaiderN in forum Grom Talk
    Last Post: 07-26-2016, 01:07 PM
  4. Ballon78 *Build* Winter Project Started
    By ballon78 in forum Grom Builds
    Last Post: 10-14-2015, 07:55 PM
