Bulletproofing a super 186
This is a discussion on Bulletproofing a super 186 within the Grom Builds forums, part of the Honda Grom Forums category; Looking to make my ported 186 virtually bullet proof. I've done a lot of reading and have an idea on most parts, but still curious ...
Results 1 to 7 of 7
Thread: Bulletproofing a super 186
    30360
    Nov 2018
    40
    I've done a lot of reading and have an idea on most parts, but still curious what your opinions are. Open to any and all suggestions. No need to be a D!(◊H34D. Thanks folks.
    I have:
    DHM 186 kit w/flashed ecu
    Custom intake
    Hindle exhaust
    TB cam
    Clutch springs 60% w/ chimera plate
    Crankcase breather
    Takegawa high flow oil pump
    I have to install:
    Ported head
    Koso dash
    Hoedar with LC2 wideband
    I need:
    AFR gauge compatible with the LC2
    cam chain tensioner
    4th bearing
    5 speed transmission?
    forged crank and rod
    Head temp sensor (read that koso gauge is generally off)
    OTB cam cover vs gromfathers vented cover?
    Koso 34mm intake/manifold
    I'll be making another custom intake
    is doing grom things
    phillybuilt's Avatar
    20097
    CT
    326
    If you still have the 2 valve head, Yuminashi chain and tensioner. If 4 valve, Takegawa or Kitaco both make HD cam chains.
    I found out about a week after ordering mine that it doesn't work for a 4 valve... doh.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    GlockPointer's Avatar
    3606
    350
    I don't see oil cooler on that list, I run Kitaco 5 row, high mount
    is fiddling with RZ350's now!
    WV_Grom's Avatar
    4799
    North Central WV
    400
    875
    A Taki catch can is the bees knees.
    I found with the BBK and the torque that comes with it, there is no need for a 5 speed. I am running a 17 Toother up front.
    Get a good seat so your hemmies are comfy. (Seat Concepts).
    If you want an accurate gauge, Opmid V2.
    2018 Grom
    Seat Concepts / Opmid V2
    30360
    Nov 2018
    40
    Iíve got the oil cooler that came with the kit. Iíve ordered a take cam tensioner. Itís a 2 valve head intake ported for the koso 34. So far no oil puking.. but before itís finished I will probably make something custom to catch any oil. Thanks for the heads up on 5 speed, Iíve got sprockets for days, will be experimenting with them. A good seat is a good idea. Thanks so far
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    I'd recommend Gromfatherz HD studs if you're interested in as bullet proof of a motor as possible.
    Sent from my SM-G955U using Tapatalk
    565
    Best thing to keep you from blowing up your motor is a cylinder head temp gauge (not talking about oil temp) and keeping it under 375F. You can also add to your list, Grom Fatherz manual cam chain tensioner, and a magnetic oil drain plug. If you want the most out of that TB cam, you should also get dual valve springs and maybe titanium retainers so you can rev past 10K.
    It seems like there is always one more thing to buy, THEN Iíll really notice a difference in performance.
  1. Finbro 186 4v 280 shipped
    By rkfinch23 in forum Grom For Sale / Wanted
    Last Post: 05-09-2017, 07:42 AM
  2. Rebuild Koso 170, Finbro 186, or stock/sell?
    By turpinator in forum Grom Performance
    Last Post: 07-16-2016, 01:47 PM
  3. Finbro 186 4v say what?
    By Fungromen in forum Grom Talk
    Last Post: 04-10-2016, 10:43 PM
  4. Help!!!!!!! Super bore crankcase set (186 until 217cc)
    By paloma in forum Grom How-To's and Guides
    Last Post: 04-17-2014, 03:28 PM
