50-50 Mild Street Build - Page 2
This is a discussion on 50-50 Mild Street Build within the Grom Builds forums, part of the Honda Grom Forums category; Originally Posted by 50-50 And I think the Grom shifter is fine if a little mushy, but this Hard Racing support bracket sure isn't going ...
Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 75
Like Tree59Likes
Thread: 50-50 Mild Street Build
    is is a centrifugal oil filter
    647
    And I think the Grom shifter is fine if a little mushy, but this Hard Racing support bracket sure isn't going to hurt. I also plan to replace the stock shift linkage with heim joints like others have done.
    The helm joints mod is cheap and made a great difference on mine, really recommend it!
    I really want to find a way to make the clutch not suck balls. I've been riding street motorcycles for over 10 years and manual clutch ATVs since the 90's, but somehow the Grom clutch makes me feel like a beginner that doesn't know WTH he's doing. It engages way too far out. Because of this I tend to apply the throttle too early so I'm using more revs than needed and also riding the clutch because it's hard to feel the engagement. The super quiet, stock exhaust also makes it difficult to hear when the revs drop due to the clutch engaging especially when I'm giving it more throttle than what is needed. And not having much torque compounds my problem with the "feel" of the clutch engagement. Shifting and downshifting are also sometimes jerky because I'm so used to having a clutch engage much closer to the bars. Any suggestions how to fix this???
    You're exactly describing what I don't like with the stock clutch. Order a Kitaco 60% stiffer clutch springs set (about 15-20$ for all 6!) and replace either 3 springs (the ones under the bolts) or all 6.
    I personally use 3 stiffer springs on the 125 and the feel is so much better, makes the engagement point very easy to find and to work with.
    For the rest I'm using a stock plate and stock discs, never had an issue with those.
    50-50 and phillybuilt like this.
    451
    Quote Originally Posted by David View Post
    Good to know about the heim joint link. I definitely plan to do that mod.
    Thank you! That information really helps. I saw there are a lot of clutch spring options - Barnett, EBC, Sex Machine, Kitaco offers springs with various stiffness, etc. I just wasn't sure which stiffness I want to get. I want an improvement in clutch engagement and feel without having a super stiff clutch.
    One thing that seems to be popping up is that I have noticed that sometimes I think I've down shifted all the way to 1st when I'm coming to a stop. I keep pushing down on the lever to make sure it's in 1st. But when I go to pull out I notice it's not in first gear so I have to click down on the lever again and then I feel it going into first. Anybody experiencing this? What gives?
    is doing grom things
    phillybuilt's Avatar
    20097
    CT
    350
    I would suggest skipping the heim joint mod and going right for the TBparts shifter. That plus the hard racing shift shaft support bracket makes it a totally different bike.
    And David is on point, get the stiffest spring you can buy which I think is the 60%. Pair that with the billet plate and you're ready to pop wheelies without worry of breaking the cast plate.
    Don't forget the stunt oil pump either! Super important piece of the puzzle.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    451
    Quote Originally Posted by phillybuilt View Post
    I don't like the idea of bolting a shifter right onto the shift shaft. Street bikes have linkages to protect the shift shaft in a crash. Dropping a bike onto the shift lever that is bolted directly to the shift shaft can cause a lot of damage. That's not a risk I'm willing to take. I'll live with the upgrade linkage and HR support bracket.
    I did run to my local Ace Hardware and they have lots of hardware, but they did not have small heim joints so I'll have to order the parts online.
    I don't know that I'll be stunting the Grom enough to need the oil pump with the tube, but I am keeping that in mind. Are there any brands besides Straight Up?
    phillybuilt likes this.
    20097
    CT
    350
    I totally understand that part of it. For what its worth, the shifter has a foldable end, just like a dirtbike does.
    Even just the bracket will make you feel like you're riding a different bike. Big positive difference for sure.
    There are a few, I'm partial to straight up pumps though. He is a forum member, and does excellent work. I was impressed with the turnaround time, and the fit and finish as well. Same pump is still going strong no issues to report.
    451
    This morning I ordered the Chimera clutch lifter spring plate and Sex Machine 30% springs. I've read lots of bad about the Koso plate so I avoided that. And 60% springs seem like overkill on a stock engine. I will find out. But I figured I might as well install these parts when I tear off the side cover for the first oil change.
    Djezspin likes this.
    616
    I ran all six 60% springs when my grom was stock bore, it was perfect when paired with the RSC clutch perch.
    phillybuilt and 50-50 like this.
    451
    With an EZ clutch I'm sure. I'm still on the stock levers and not sure what I want to switch to. Springs are cheap enough to replace them if the 30% isn't stiff enough for me. I think the RSC stuff is expensive for not offering adjustability of lever position like ASV, CRG, Pazzo, etc.
    is between rain storms :-)
    FluxCapacitor's Avatar
    31500
    2887
    112
    I ordered the Vagabond fender kit, it should be here by Friday!
    Can't wait
    https://www.vagabondmotorsports.com/...der-eliminator
    50-50 and Djezspin like this.
    451
    Quote Originally Posted by FluxCapacitor View Post
    Can't wait
    Looks like a nice piece! I like how the turn signal mount is integrated into the bracket. I wish the Yoshi was like that.
    So the post office tried to deliver my PV3. Apparently Hard Racing requires a signature which 1. is retarded and 2. I didn't see them state ANYWHERE that a signature was required. I'm annoyed to say the least. You spend almost $450 with them, don't get free shipping (every other place I shop would give free shipping after spending a half of that or less) and then they don't tell you that a signature is required. The customer service was excellent before the order though. They answered all my questions. And they preload the maps onto the PV3. And that's why I went with them.
  1. Alex's Grom Mild Build
    By Alex_Grom&Ruck in forum Grom Builds
    Last Post: 01-13-2019, 09:01 PM
  2. [Build] my street/race/stunt grom build
    By STR8GROMN in forum Grom Builds
    Last Post: 08-05-2015, 06:24 AM
  3. BOTWALKIE's Mini street/race Build
    By botwalkie in forum Grom Builds
    Last Post: 08-02-2015, 11:31 PM
  4. MILD "FAM" Tee - Unofficial Super Supday 2014 Shirt - Pre-Order
    By fatphos in forum Parts for Sale / Wanted
    Last Post: 03-29-2014, 07:01 AM
Tags for this Thread
