Fender eliminator
Fender eliminator
This is a discussion on Fender eliminator within the Grom Builds forums, part of the Honda Grom Forums category; What fender eliminator kit are you guys running and which do you recommend with turn signals?...
Results 1 to 3 of 3
  • 1 Post By Actech
Thread: Fender eliminator
    31014
    8
    Fender eliminator
    I have the Vagabond eliminator. There are two types...
    1. uses stock taillight, license plate light and turn signals.
    https://www.amazon.com/Vagabond-Moto...s%2C205&sr=8-3
    2. eliminates the license plate light and turn signals. You can use stock taillight, or buy an aftermarket taillight with integrated turn signals.
    I got the first one because I don't want integrated turn signals and needed turn signals because the bike was initially registered in California and we all know their laws. I'm about to pick up a set of Rizoma turn signals soon.
    Check around the build forum and you'll see the many types of eliminators and everybody loves the one they chose. Good luck.
    31014
    8
    Thanks for the help. Just ordered mine.
    Djezspin likes this.
  1. MNNTHBX fender eliminator and Yoshi fender eliminator
    By grom_cam_17 in forum Parts for Sale / Wanted
    Last Post: 10-02-2017, 11:50 PM
  2. FOR SALE: Fender Eliminator,Front Fender, Brembo Kit
    By Challyfreel in forum Parts for Sale / Wanted
    Last Post: 10-30-2013, 09:31 AM
  3. Replies: 61
    Last Post: 09-21-2013, 06:01 PM
  4. ComposiMo TidyTailť Fender Eliminator!!!
    By ComposiMo in forum ComposiMo
    Last Post: 09-05-2013, 10:09 AM
  5. Tail Tiddy / Fender Eliminator Kit
    By rkwfxd in forum Grom Talk
    Last Post: 06-21-2013, 10:21 AM
