Build: Super Stock dirt SF - Page 3
Super Stock dirt SF
This is a discussion on Super Stock dirt SF within the Grom Builds forums, part of the Honda Grom Forums category; I love the fender, I still have mine so I might put it on when needed in wet conditions. Put a few hundred miles on ...
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 33
Like Tree7Likes
Thread: Super Stock dirt SF
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    I love the fender, I still have mine so I might put it on when needed in wet conditions. Put a few hundred miles on this weekend since the weather was nice. The 150 kit pulls super hard and revs high. Kept up with a 250 swap with the maxxis 6024s.
    I put Diode Dynamics rgbw demon eyes in the headlights today, turned out pretty dope.
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    nearly done with preparations for my 1,400 mile round trip to WI and back to NY.
    428 superlite sprockets (15/32) w/ 428 DID ZX Chain
    120/140 Power Pures
    Givi A660
    562
    Those BMX axle sliders look like they would do more harm than help. You've never had them catch roots and rocks when you went off-road?
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    nope, never had an issue
    Sent from my SM-G955U using Tapatalk
    is a Gromlet
    Vinnie13's Avatar
    31300
    50
    i am VERY interested to hear how the 150 does on the long journey, and what sort of routes you may take (highway, backroads, etc.) that windscreen looks like it will do wonders. please keep us updated.
    2018 Yellow Grom (Her's)
    2018 Red Grom (Mine)
    2017 Triumph Bonneville Bobber (Her's)
    2016 Harley Low Rider (Mine) For Sale
    2012 Ducati Diavel (Mine)
    1979 Yamaha QT 50 Yamahopper (project)
    1979 Yamaha XS650 (project)
    2017 Ford Focus RS
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    Well, that was a short trip. Made it half way to Buffalo and the motor blew up.... I'll tear it down once I have it back home.
    Confused since it made it over 1,000 miles before blowing up, so I wonder if a line from the oil cooler clogged and caused it to overheat.
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    well the motor is fine.... crankshaft not so much.
    141
    The Demon Eyes are awesome!
    That really sucks it blew up!
    Just saw you added more photos. I can't believe the crank snapped! Are they a weak spot on the Grom?
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    2.5k
    43
    apparently it's a relatively common failure, forging flaw that can cause cracks near the flywheel key area.
    I'm still kinda shocked, didn't expect this to be the point of failure!
    I even added the take crank support bearing....
    New OEM crank and rod is only like $90 tho.
    563
    That sucks. Good luck with the crank replacement. I've read of the these incidents. Hopefully your new crank is a good one. Make sure you get yourself a new woodruff keys for both left and right side and might as well get a new right side crank bearing. I have the Takegawa tensioner and it's a quality piece. And if you've never done it before, splitting the case for the job isn't all that bad. Good luck.
    altek likes this.
  1. Dirt Bike Build
    By WV_Grom in forum Grom Builds
    Last Post: 10-22-2017, 08:04 PM
  2. Grom and Dirt bike helmets
    By tpolaski in forum Grom Pictures/Videos
    Last Post: 01-11-2015, 06:10 PM
  3. Need newbie (to dirt) advice.
    By Top Gromen in forum Off-Topic
    Last Post: 07-16-2014, 03:56 PM
  4. Short little dirt session to the lake.
    By Floppyzebra in forum Grom Pictures/Videos
    Last Post: 05-22-2014, 11:42 AM
  5. Grom mini dirt track session
    Last Post: 02-23-2014, 10:27 PM
