Build: Super Stock dirt SF - Page 2
Super Stock dirt SF
This is a discussion on Super Stock dirt SF within the Grom Builds forums, part of the Honda Grom Forums category; I will answer why I went BBK kit via 2V or 4V. First off I met a few grom owners with the super 125cc kit ...
Results 11 to 20 of 20
Thread: Super Stock dirt SF
    7,623
    First off I met a few grom owners with the super 125cc kit that REN sells or other vendors sell. For one thing the super 125 kit is great for reliability and will cruz all day 70-80mph with the correct ECM, airbox, exhaust, and mapping.
    I had both the 2V kits 170cc and 183cc and now the 4V kits Takegawa 181-4v.
    From having been one of the first grom owners testing and tuning both these types of kit I found out that things to consider is good A/F mapping, good cooling, and correct gearing setup.
    The main thing that I realized that hindered all my builds may it be 2V or 4V kits was the CCV system. With out going into details I sure if I had found the right CCV system I would maybe still be running 2V engines. CCV= Crank Case Venting. As I said with out understanding internal crank case pressure, blow-by and such I would never have gotten my engine to last and run as good as they do now.
    Finding the right ECM system is the second most important area most grom builders need to take into consideration. I'll let the builder decide how much they can spend or money wasted to figure out what works or not.
    Most grom owners on this website need to read everything on this website pertaining to building a good engine and decide what hardware they can afford or should buy for their type of riding style or what they want to accomplish in your build.
    Below I will list the items that I think that is important for any grom build starting with mild build to wild build.
    1. remove oil spinner and replace with Kitaco Clutch side cover. "advantage, you get a real oil filter, ports for external oil cooler, reduced spinning weight"
    2. Mod airbox or aftermarket air-box system
    3. full exhaust system, "NO crappy slip on's, want noise drill some holes in your stock muffler"
    4. 60% stiffer clutch spring esp if you are going BBK, anything less than 60% you will experience slippage
    5. Port match any intake or exhaust port on the head with the hardware you are using.
    6. Porting of the intake on the head is very important for HP
    7. CCV, get a good Crank Case Venting system, there is a lot of choice out there some good and some not so good.
    8. get the correct F/I for your engine.
    9. Reduce weight either on the grom or on yourself will help out the total experience in Hot Rodding the grom.
    Good Luck all and ride safe.
    cyclesurferscott's Avatar
    29992
    13
    Quote Originally Posted by altek View Post
    I'd rather keep the stock bore and maintain as much of the Honda reliability as I can. I've heard good things about about RMW kits, so I figured if I was going to spend the coin, may as well try to keep the problems to a minimum. I know lots of riders have super quick, well tuned machines running big bore kits and or 4v heads, but it seems more of a gamble than the super 125 kit.
    I decided to keep the Grom on the road for the rest of the season and start once winter hits, so next spring hopefully I'll have some comments.
    Sent from my SM-G955U using Tapatalk
    Gotcha. Makes sense .... I have seen a lot of dudes liking the idea of keeping the stock OEM reliability of the Honda components. Look forward to hearing what you think in the future.
    29992
    13
    Lots of good feedback and knowledge in this post... totally get ya on the good CCV. Without it your gonna suffocate the engine and cause lots of oil oil consumption as well as possible internal damage and lack of power.
    I just asked the question to the original poster because I was curious his particular reasoning
    Cheers
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    800
    20
    Slight change of plans. I'm sending the super 125 piston, and head gasket + Tbolt cam back to RMW, and I'm essentially swapping for the new super 150 kit. Figured I was spending the cash building the bike, why not get a little extra kick. (Slippery slope, I know)
    29992
    13
    Awesome! That’s the kit I am leaning towards as well. Haven’t heard much about the 150 kit. Wonder what they are seeing speed wise with these kits and the average size rider .... now to have a buddy buy the kit and ship it too me good ol CA.
    Girth Brooks's Avatar
    31112
    15
    Can OP or anyone else who has done a front fender delete like the one above tell me how you secured the brake line bracket that's attached to the stock front fender?
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    800
    20
    Quote Originally Posted by Girth Brooks View Post
    oh boy, I haven't updated this in a hot second. crap. oh well: I didn't secure it at all, and I've had zero problems in the last 1.6k miles
    Girth Brooks likes this.
    altek's Avatar
    29108
    Jun 2018
    Rochester NY
    800
    20
    All done for now.
    Kitaco 3 row oil cooler and catch can, new exhaust, and monkey fork guards.
    mikochu and CiscoSanJose like this.
    2205
    Orlando, Florida
    94
    It's like a splittin' image of my Brute GP! Congrats!
    altek likes this.
    mikochu
    2018 Honda Grom (Matte Gray)
    Engine: DHM 186 | 2x ECU: DHM 186 & Stock + PV3 | Koso DB-03R w/ RaceDash | UEGO | MTake | DHM Header + Cheap Slip-on | Kitaco 60% Springs + Stock Plate | Superlite 16/32
    Suspension:
    Chassis: Chimera Race Bolt | Speed Spacers | Womet-Tech Sliders | NDC Adjusters | TST Fender Eliminator | Steady Garage Flush Signals | ProTaper SE Honda Mini | Neverlandback Mirrors | Corbin Saddle | Driven TT Rearsets
    1000
    264
    Nice touch. The Monkey fork guards are perfect for a dual sport. I put a low front fender on mine, but they also mount high same as on the Monkey.
    altek likes this.
    TOCE Dual Exhaust
  1. Dirt Bike Build
    By WV_Grom in forum Grom Builds
    Last Post: 10-22-2017, 08:04 PM
  2. Grom and Dirt bike helmets
    By tpolaski in forum Grom Pictures/Videos
    Last Post: 01-11-2015, 06:10 PM
  3. Need newbie (to dirt) advice.
    By Top Gromen in forum Off-Topic
    Last Post: 07-16-2014, 03:56 PM
  4. Short little dirt session to the lake.
    By Floppyzebra in forum Grom Pictures/Videos
    Last Post: 05-22-2014, 11:42 AM
  5. Grom mini dirt track session
    Last Post: 02-23-2014, 10:27 PM
