NEW NEW - ComposiMo RaceBarZ Get LOW on your bars!!! - Page 10
This is a discussion on NEW NEW - ComposiMo RaceBarZ Get LOW on your bars!!! within the ComposiMo forums, part of the Vendors category; Originally Posted by Grom314 Just put these on. It wouldve been nice to get instruction being the fact that I put them on and notice ...
Page 10 of 10 FirstFirst ... 8 9 10
Results 91 to 99 of 99
Like Tree39Likes
Thread: NEW NEW - ComposiMo RaceBarZ Get LOW on your bars!!!
  1. #91
    is Waiting for other riders to
    hit me up. Let's go for a
    cruise in the great city of
    chicago
    Grom314's Avatar
    5306
    May 2015
    Chicago
    51
    42
    Quote Originally Posted by Grom314 View Post
    Just put these on. It wouldve been nice to get instruction being the fact that I put them on and notice many problems after. Pretty pissed that I have to take everything off and start from the beginning. I don't recommend these bars. They should've come drilled and ready to go. Not happy at all.
    Finished them now and I like them a lot but instruction should be mailed with the parts like mnnthbx parts.
  2. #92
    5145
    Apr 2015
    100
    It would be perfect if can use scotts damper on it
  3. #93
    mrclowny's Avatar
    6433
    Oct 2015
    Earth/NA/CA/LA
    369
    I think I'd like to get these next.
    Does this work with RPM's dual Gauge Pod?
    Does the bar ends come off? So I can use my MNNTHBX bard ends?
  5. #94
    7865
    1
    Will this fit 2017 models? How much shipped too hawaii
  6. #95
    TheW's Avatar
    5587
    Jun 2015
    Northcentral Illinois
    585
    77
    NEW NEW - ComposiMo RaceBarZ™ Get LOW on your bars!!!
    Getting ready to install my bars today. I've read the instructions that are linked in Composimo's site. I am going to use bar end mirrors (CRG Arrows). In reference to measurements provided in the instructions to drill the holes.....do I need to take into account the width of the mirror's clamp when drilling it (i.e. move the hole inward to account for the mirror clamp) or is there enough bar left over to clamp on to with the provided measurements? Looking at the pictures in the instructions, there appears to be a good bit of bar protruding beyond the grip ends. Any feedback is greatly appreciated.
    Edit: Bars are installed.
  7. #96
    HifiExpat's Avatar
    10969
    Middle East
    1500km
    325
    Is there a compatible steering damper?
    Anyone using these bars note the weight is too forward leading to a feeling of loss of control in the back (as posted elsewhere on the forum)?
  8. #97
    is unavailable for comment
    28830
    Jun 2018
    25
    I noticed composimo are currently running a summer sale with 20% off for another couple of days and I was tempted by the look of these but I have a query.
    Width is an issue for me. Most aftermarket bars are wider than the stock bars tip to tip. How wide are these ComposiMo Racebarz?
    2017 Honda MSX125SF ABS / 2018 Honda Grom ABS - Lemon Ice Yellow
    BST Carbon Fibre Wheels
    JT Sprockets JTF273.15, PBI Sprockets Aluminium 428 34T, D.I.D Pro Street X-Ring 428VX
    K&N HA-313 Air Filter,
    Kitaco Clutch Cover, Billet Clutch Lifter Set, Super Oil Pump, Carbon Oil Catch Tank & Super Throttle
    Ohlins FDK111 Cartiridge Kit
    Shorai LFX14L2-BS12 LiFePO4 battery
    H2C Tail Tidy, Belly Pan, Fly Screen, & Rear Splash Guard
    OTB Vision Mirrors, Chain Adjuster V2, Transparent Cam cover
  9. #98
    mrclowny's Avatar
    6433
    Oct 2015
    Earth/NA/CA/LA
    369
    Quote Originally Posted by YoAdrian View Post
    I noticed composimo are currently running a sale for another couple of days and I was tempted by the look of these but I have a query.
    Width is an issue for me. Most aftermarket bars are wider than the stock bars tip to tip. How wide are these Composimo Racebarz?
    You can change the total width since the actual bars are held by the mount. I do want to say you can get it pretty close to the stock width.
    I had the same concern but I was happy with the result.
  10. #99
    28830
    Jun 2018
    25
    Yeah I figured that the clip ons could be adjustable and slide up and down the clamp. I'll rephrase the question then. Any idea how wide the ComposiMo RacebarZ are at their full extension?
    The stock are around 700mm. Ideally I'm looking for something equal, so I don't have to drill out the stock bar's bung to use another bar weight, or less than 700mm to give me more clearance wheeling the Grom in and out of my house.
  1. What handle bars?
    By jmzd4 in forum Grom Talk
    Last Post: 10-13-2016, 11:39 AM
  2. somone help me with some bars!!
    By xconftw_florida in forum Grom Gear and Accessories
    Last Post: 10-04-2013, 07:01 PM
  3. Pro Taper Bars
    By Bf519 in forum Grom Talk
    Last Post: 10-04-2013, 07:25 AM
  4. Wind deflectors and engine-bars?
    By Jongsanim in forum Grom Gear and Accessories
    Last Post: 09-26-2013, 01:43 PM
  5. Drag Bars Or Clip-Ons On A Grom?
    By 4Nines in forum Grom Talk
    Last Post: 09-03-2013, 08:31 PM
composimo bar grom
composimo grom
composimo racebarz
edprez grom
grom clip ons
grom race bars clip on-bars
honda grom clip on bars
honda grom custom
