BBK Koso 170 or Kitaco Neo 181 - Page 2
This is a discussion on BBK Koso 170 or Kitaco Neo 181 within the Monkey Builds forums, part of the Honda Monkey 125 Forums category; Originally Posted by solidjohnny Luckily, the power I have now is enough....but....I want more.... Do you know what I mean? Like, I'm just riding it ...
Results 11 to 15 of 15
Like Tree6Likes
Thread: BBK Koso 170 or Kitaco Neo 181
    is In love with motorcycles since
    1979
    31560
    Caracas - Venezuela
    52
    Luckily, the power I have now is enough....but....I want more.... Do you know what I mean? Like, I'm just riding it for now till I save money for the next stage (next stage is a 4 valve bbk kit). I do have a perfecting fine ZX-6R that just collects dust in my garage. I dunno what's wrong with me....
    Thanks for the answer, and yes, I know that sensation Ha Ha Ha, is addictive
    solidjohnny likes this.
    Honda monkey's Avatar
    30938
    Feb 2019
    133
    If you port your heads on any grom engine build and port match your intake and exhaust I/D and have the right throttle body,inlet tube and F/I and ECU with the proper mapping you will be riding all day smiling.
    Control your crank case pressure-oil catch can setup and you will reduce heat, combined with a 5 row external oil cooler and proper oil changes and you should be good to go.
    Yes big difference between a 2v vers a 4v head.
    If you have a old tired engine with 7-10K WOT miles on the engine do yourself a favor and replace all the transmission bearings, they are cheap and will make your transmission happy again. Would I go 5 speed yes. I have Zero issues with my Takegawa 5 speed and I even did not have to buy a speed healer or special adaptor for my speedo everything worked plug and play.
    Just monitor your temps on your head, cylinder and oil and you would be ok. I found on my Takegawa 181-4v build the average temps on the head are between 190-220F, the cylinder between 190-240F, and oil between 160-210F going between 35mph to 55mph, anything over that and you are seeing 240F on the cylinder, 220F on the head and 220F on the oil and rise as you go up in mph like say up to 80mph for long distance.
    Attachment 80322
    Awesome info, how and where exactly do the temp gauge leads attach to the motor? What would you do differently, if anything? I NEED that setup. I like the NASA look, functional techno-bling is my term. Thanks again for your years of R n D.
    683
    Quote Originally Posted by Honda monkey View Post
    I have a TTO head temp gauge which reads from the base of the spark plug. I also read the oil temp off the aRacer display. Before I had the aRacer ecu, I was using the OPMID oil temp gauge which reads off the stock oil temp sensor. The TTO head temp gauge ($45-55) is for sure the most important thing to have. From all the sources I've found on air-cooled engines, you don't want to see temps go over 375F. Cisco is running the OPMID oil temp gauge and AFR gauge on a fancy mount. Plus his fancy temp gauge, not sure where he is pulling head temps from.
    8,191
    I use this cheap and it works. I mount it on a smartphone bike/MC holder using double back tape and I spray hair spray over the edge of the face to make it water proof to keep water out. Only thing missing is a led light for checking the meter reading at night and I might DIY the case to have some kind of night vision reading. One of the leads go to the head and the other one goes to the cylinder and using the mounting bolts on the head and cylinder as the connection point for the meter.
    https://www.ebay.com/itm/NEW-Digital-Dual-Two-Channel-Thermometer-2-K-Type-Thermocouple-Sensor-GM1312/232634486542?epid=2222738148&hash=item362a188f0e:g :9HwAAOSwKUhZrRLB
    30938
    Feb 2019
    133
    Thanks. I will order the tto temp gauge. Head temp below 375, got it!
    Attached Thumbnails Attached Thumbnails BBK Koso 170 or Kitaco Neo 181-b19e1195-35e0-4bef-a864-84b0f8244b2c_1559075357658.jpeg
  1. Replies: 4
    Last Post: 05-13-2019, 05:52 PM
  2. Such a thing as a Kitaco Neo 181 4V?
    By WV_Grom in forum Grom Performance
    Last Post: 06-06-2018, 10:01 PM
  3. Replies: 10
    Last Post: 10-06-2017, 05:11 AM
  4. Replies: 5
    Last Post: 05-21-2017, 07:14 PM
  5. Kitaco 181 Neo BBK
    By 8701michael in forum Grom Talk
    Last Post: 03-12-2017, 07:19 AM
