15/37 gearing. How far up or down accurate speedometer?
This is a discussion on 15/37 gearing. How far up or down accurate speedometer? within the Grom Performance forums, part of the Honda Grom Garage category; Hit 67 mph on stock speedo, wondering if accurate or true speed is off by how far.thanks in advance for any info....
Results 1 to 8 of 8
Thread: 15/37 gearing. How far up or down accurate speedometer?
    jsk
    jsk is offline
    301
    37
    is dialing in the bike for my
    wife !
    32050
    Ottawa, ON, Canada
    3400 km
    124
    Try entering your setup here:. https://www.gearingcommander.com/
    2015 OG Grom in Yellow - AODRacing loop exhaust, ContiScoot tires, EBC HH front pads, RideItMoto levers, Renthal kevlar grips, Road low bars, CJR ECU, TB cam, MNNTHBX Mtake, Outerwears, Koso temp gauge, short shift linkage, TST sliders, Aliexpress tail tidy, Aliexpress axle sliders
    Pending - oil cooler, CoreMoto braided lines, high mount exhaust, rearsets and GP shift conversion
    721
    Quote Originally Posted by jsk View Post
    Stock gearing is 15/34 and 15/37 gearing is 9% lower, so your speedometer reads 9% faster. This makes an indicated 60 mph on your speedometer actually 55 mph. This is in addition to the stock speedometer's already high reading which makes your actual speed about 53-54 mph.
    jsk
    jsk is offline
    301
    37
    Quote Originally Posted by tooter View Post
    Thank you for the detailed explanation.That was exactly the information I was looking for.
    7328
    Coastal NC
    I have one method to recommend. There are numerous speedometer apps that you can download for free.
    1. Download an app.
    2. Turn it on and run the Grom on a level space at 60mph (based on the phone app speed). Identify the speed you Grom indicates.
    3. Upon returning from your ride, you can calculate the variation of Grom indicator/Actual speed.
    There are several electronic correction devices which can be wired (Plug and Play) into your wiring harness to adjust the corrected speed error with whatever gear choices you make.
    Good luck!
    REinNC
    32386
    Download a speedo app for your phone and check your speed with that.
    jsk
    jsk is offline
    301
    37
    Thanks for the other suggestions to figure out actual top speed vs speedometer. Much appreciated.
    is Member
    29978
    USA
    5200
    38
    I checked my speedometer on stock gearing with GPS and radar and it was dead on, no more than 0.5mph difference at 55mph. Also checked the odometer over a ~15 mile distance and found it to be near-perfect.
    I have ridden a Grom with lowered gearing and found the stock setup to be much better, I think most of what people 'feel' when they mess with the gearing is a placebo based partly on their expectations, and partly on their now-inaccurate speedometer readings.
    If you do change your gearing though, you should consider a speedometer recalibration tool. In addition to avoiding the nuisance of constant mental adjustments to guess your speed, you will also preserve the accuracy of your odometer for maintenance intervals, resale value, and in some cases insurance purposes.
    https://www.amazon.com/OclockLabs-Sp...dp/B01JLL4V3A/
