Deal alert - Brembo 4P-30/34 40mm calipers - Page 3
This is a discussion on Deal alert - Brembo 4P-30/34 40mm calipers within the Grom Performance forums, part of the Honda Grom Garage category; Confirming the caliper needs the rotor loosened to get the wheel on/off. Kinda a pain but not terrible. The stock master is fine with the ...
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Like Tree8Likes
Thread: Deal alert - Brembo 4P-30/34 40mm calipers
    31676
    132
    The stock master is fine with the new caliper. Effort and travel is increased but in a way that allows better modulation. Ideally, the master would be changed but it is not at all a requirement.
    117
    Can you loosen the caliper instead of the rotor?
    is is installing a crank and 5
    speed
    OpusNectar's Avatar
    28210
    San Diego
    640
    The way the caliper is fastened and the tight tolerances make that impossible unfortunately.
    2015 Grom
    Koso 4V | Aracer AF1, DG1, MiniPlus2 | Kitaco Crank | Takegawa 5 Speed
    Kitaco CCT | Takegawa Oil Pump & 4th bearing | GF Billet Cam Cover
    34mm TB | MP Rev2 | PT CR High | Renthal Clamps
    Kitaco Clutch Cover & Oil Cooler | GF Speed Spacers
    Brembo 4P & P34 | BRAKING Rotors | Galfer SS Lines
    Driven TT Rearsets | OTB V2 Adjusters | MNNTHBX Swingarm Bushings
    RacingBrothers Sus. | Hindle High Mount | Saddlemen Seat | 428 conv. 15/36
    Mitas MC35S 100/120 | Gcraft Linear Damper Setup
    31676
    132
    Loosening the rotor is only 4 bolts, anyhow.
    31676
    132
    Shot of the installed results:
    OpusNectar and IntegraXTR like this.
    32366
    38
    Nice. I imagine the Brembo setup is heavier than the stock.
    is a centrifugal oil filter
    671
    Hey mrsaturn, is the rear caliper reference 20B85273? It's a ''crab'' but looks slightly different to other ones.
    I'd like to use one on the front.
    31676
    132
    Quote Originally Posted by David View Post
    That's the one, yes.
    David likes this.
    32604
    Sep 2019
    The look of the Brembos are awesome. But the question is, how does it feel? I like the lever feel with the stock, but just want more clamping power
    speed
    OpusNectar's Avatar
    28210
    San Diego
    640
    Quote Originally Posted by IntegraXTR View Post
    Amazing feel, all the modularity you need with more clamping force you'll ever use. Stock master does the job perfectly.
    2015 Grom
