Dynojet PV3 and Power Core - Juicy Detail and Help Inside - Page 22
This is a discussion on Dynojet PV3 and Power Core - Juicy Detail and Help Inside within the Grom Performance forums, part of the Honda Grom Garage category; Originally Posted by 50-50 What's the reasoning for only smoothing small areas? Most of his map is between 12.8 to 13.1 AFR. I would turn ...
Page 22 of 22 FirstFirst ... 12 20 21 22
Results 211 to 216 of 216
Like Tree76Likes
Thread: Dynojet PV3 and Power Core - Juicy Detail and Help Inside
  1. #211
    122
    Most of his map is between 12.8 to 13.1 AFR. I would turn on dynamic coloring and look for rich spots and try to bring the 12.8 areas up to 13.1
    I'm guessing it would be a little more fuel efficient and probably make around the same power. You could try smoothing a huge section if you want. You can always revert back to the old map if you don't like the results.
    Quote Originally Posted by obijuanito View Post
    In case i rescale the fuel table (rpm axis) do i have to modify (with the exel solution) another table, like for example timing table? Or just the fuel table? Or another tables and settings too?
    I think there's 4 tables it will affect. Injector pulsewidth normal and fast idle, and ignition timing neutral and in gear.
    obijuanito likes this.
  2. #212
    obijuanito's Avatar
    4704
    448
    As the bike iddles at 1500rpm could i use the 1100 and 1300rpm cells to use them in the higher rpm range?
    Let me explain...
    I would erase the data in the 1100 and 1300 rpm cells and relocate from there the whole grid (1200 rpm data would be in the space where 1100 was and 1400 rpm data would be in the cells where 1300 was). At the end of the grid i would have 2 empty cells. Then i would change the 9250 cell and would raise it to 9500 and the 2 empty cells would be 10000 and 10500 rpm cells...
    Would this be a good option?
    Enviat des del meu LG-H870 usant Tapatalk
  3. #213
    is 8.5.Zer0's Fastest!Grom
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    798
    Affects 9 areas of the map:
    Injector pulse width - Fast Idle, Normal , Tps Failed
    Decel Timing Override - Override active igniton timing
    Limiters - Ignition Timing, Max and Min
    Ignition Timing - Nuetral, In Gear, Tps Failed
    When I made changes to the axis for Injector pulsewidth normal everything carried over to the associated tables
  5. #214
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    798
    Im sure that would work, changing timing tables as well, in gear for sure not sure if nuetral would be needed.
    I think Mr Saturns method would be easier, cause for the most part the last three cells from 8500 to 9250 the timing markers the same. There is a little area at the 8500 rpm range around 20 to 60% tps the timing differs by around 1degree
  6. #215
    obijuanito's Avatar
    4704
    448
    I just did a map the way saturn and dubsolo suggested (changing last 2 cells rpm values) and will try that map.
    Thanks guys!
  7. #216
    31676
    133
    Highlight the whole map, and hit 'S' about 10 times and that should tell you why.
    If you use the AutoTune script, you only want to smooth the modified areas, otherwise you'll pull the 'on target' areas out of the correct IPW value. 1 step forward, 2 steps back, in other words.
    DJMatt likes this.
