Dynojet PV3 and Power Core - Juicy Detail and Help Inside - Page 2
This is a discussion on Dynojet PV3 and Power Core - Juicy Detail and Help Inside within the Grom Performance forums, part of the Honda Grom Garage category; Error 404... Enviat des del meu LG-H870 usant Tapatalk...
Page 2 of 22 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 216
Like Tree76Likes
Thread: Dynojet PV3 and Power Core - Juicy Detail and Help Inside
    obijuanito's Avatar
    4704
    448
    Error 404...
    781
    Quote Originally Posted by Dyno Dan View Post
    Try it now. I was uploading from a crappy connection on a Delta flight.
    Good to go. I can download it without any issues.
    is 8.5.Zer0's Fastest!Grom
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    798
    Here's a quick overview of the approach to edit your calibration........at least one method of the tuning process / calibration editing that is. Your approach may differ.
    https://www.dropbox.com/s/6pg2k8aa0y...dits.docx?dl=0
    Mr. Dan can you please give a little more in depth detail about the O2 transition voltage setting?
    shows 1 thru 4 what is this (RPM Range?) if so what are the ranges?
    last email I sent to DJ customer service about this area was told rpm range,,, when I asked what were the ranges, where and why? Has gone un-answered almost 2weeks now
    You have been more help here on this forum, than E-mails to DJ"s own customer service.... So thank you for that
    50-50 and obijuanito like this.
    122
    If you raise the rev limit to 13,000 can you add more rows to the fuel table? I found out that you can change the values in the rpm column. I think there's 29 rows, can you add more or do you just have to space them out differently?
    781
    I read the two documents last night and they're a nice start, but we need a lot more information.
    29816
    46
    Traveling this week, but I hope to add more soon.
    781
    Awesome to hear! Are you a Dynojet employee or just an affiliate or whatever they call their members?
    29816
    46
    C3 allows you to rescale the breakpoints on X and Y axis, but you can’t add more. The table size is an “ECU thing” not a “C3 thing”. Be mindful of that when you change the X or Y values the table data (Z) does not automatically shift to realign with the previous association to the X or Y values. Hope that made sense? So you you would need to shift or interpolate values to get them aligned properly.
    Example. X axis value of 60 in the 8th column, and then at a Y value of 5000, and then has an associated Z value of 2.0ms. Now change the X axis 8th column value to 90....ok, the Z value doesn’t budge and is still 2.0ms, All the while the operating conditions of the engine are completely different.
    Typing from my phone. Sorry I couldn’t get screen shots.
    dubSolo's Avatar
    27817
    Mar 2018
    6,661
    798
    BUMPING This... Other Questions have been responded to that were pitched after this one, If the question cant be answered at the moment would be nice just to get a validation response.
    865
    If you raise the rev limit to 13,000.............
    I have no opinion on this, nor am I taking any sort of a positon regarding RPM limits, but....I AM wondering.....how safe is it to raise the RPM to such a high value?
