OG Owners with DG Header + OEM Muffler
This is a discussion on OG Owners with DG Header + OEM Muffler within the Grom Performance forums, part of the Honda Grom Garage category; After a failed attempt (sort of) at removing the cat from an OE header pipe, I ordered (and just received) a DG Performance header. My ...
Results 1 to 3 of 3
Thread: OG Owners with DG Header + OEM Muffler
    is MKEthunderknuckle
    5564
    Jun 2015
    Milwakee, WI
    95
    My intent is to install with the OEM muffler. I’ve seen multiple reports of people successfully installing this combination.
    I can’t get the DG header to fully seat into the muffler. There is still a gap in the split end of the muffler because the header won’t seat. I had to remove the OE muffler gasket, so that’s out of the way.
    Did anyone else with this combo have to grind or “fit” their DG header to get it to seat properly?
    ETA: Picture
    5564
    Jun 2015
    Milwakee, WI
    95
    I think I’m just going to grind down the header until it’s a tight slip fit, then add some Ultra Copper RTV for good measure.
    2,369
    I had to slot the holes in the stock muffler so that it slid all the way down onto the header.
    After about 6 months the muffler at the smallest portion at the top of your picture cracked completely due to lack of gasket and vibrations. I ended up cleaning up the end of the stock exhaust pipe, welding on a thin walled piece of pipe that was the same size as the end of the header, then got some metal flex pipe to join the two.
