Will I need a fuel programmer for Airbox Mod + Exhaust
This is a discussion on Will I need a fuel programmer for Airbox Mod + Exhaust within the Grom Performance forums, part of the Honda Grom Garage category; Hey, so I have the AR exhaust currently installed on my grom. I am looking to do the airbox mod for a little extra torque, ...
Results 1 to 7 of 7
Thread: Will I need a fuel programmer for Airbox Mod + Exhaust
    is An idiot
    27361
    Feb 2018
    Downingtown, PA
    59
    Hey, so I have the AR exhaust currently installed on my grom. I am looking to do the airbox mod for a little extra torque, but am worried about the bike running lean. Will I need a fuel programmer if I also do the airbox mod, or can I just reset the stock ECU and be fine?
    Just reset the ECU and you'll be fine.
    https://www.hondagrom.net/forums/13-...ion-video.html
    If you do start looking at BBK or changing the cam out then you'll need to look at fuel options.
    455
    Quote Originally Posted by Japspec View Post
    You'll likely be fine. I'm running an open intake and free flowing exhaust so to make sure the engine is getting enough fuel I installed a Yuminashi ECU. It adjusts itself and doesn't need to be reset like the stock ECU.
    IXIL Dual Exhaust
    Kitaco Case Cover w/Oil Filter
    Takagawa High Volume Oil Pump
    is An idiot
    27361
    Feb 2018
    Downingtown, PA
    59
    Thanks guys! I'll just reset the ECU afterwards and see how it goes.
    is a Gromlet
    Vinnie13's Avatar
    31300
    84
    how'd it turn out?
    31288
    12
    Quote Originally Posted by tooter View Post
    Was the re-wiring part confusing on the yuminashi? Since the website says if it's a newer gen Grtom the wires don't match up.
    7,840
    Quote Originally Posted by Big Cam View Post
    No different than when you setup a Finbro ECU , just de-pin a couple of wire and more it to a new location and you're done
    Will I need a fuel programmer for Airbox Mod + Exhaust-repin-2017-grom125-sf-usa-version-og-grom125-ecu.png
  1. Replies: 4
    Last Post: 04-23-2019, 09:41 AM
  2. Fuel programmer needed?
    By Nbgrommer in forum Grom Performance
    Last Post: 04-03-2019, 12:53 PM
  3. Replies: 21
    Last Post: 08-30-2016, 07:04 PM
  4. FS: Honda grom EJK fuel programmer
    By badassxr50r in forum Parts for Sale / Wanted
    Last Post: 09-09-2015, 10:55 PM
  5. Replies: 5
    Last Post: 08-08-2014, 09:00 PM
