Stock Grom Engine 0-60 mph almost :) in 13 sec. Nothing but the bolt on mods! - Page 6
This is a discussion on Stock Grom Engine 0-60 mph almost :) in 13 sec. Nothing but the bolt on mods! within the Grom Performance forums, part of the Honda Grom Garage category; The GPS has humbled many people. Just like the Dyno. I will like to add that it sounds like you got a good running Grom ...
Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 66
Like Tree47Likes
Thread: Stock Grom Engine 0-60 mph almost :) in 13 sec. Nothing but the bolt on mods!
  1. #51
    596
    I will like to add that it sounds like you got a good running Grom to start with. When my grom was stock bore, it would never run as fast as yours.
  2. #52
    30744
    SFV, Los Angeles
    980
    79
    Yeah you all...
    So a two way run peak to peak averaged 70mph on the GPS. This was the west to east the other is the east to west. Check out the home to west and notice the GPS and the Speedo off by 15 mph because the GPS can't keep up with the acceleration of the Grom!
    Davey K and Phoenix like this.
  3. #53
    30744
    SFV, Los Angeles
    980
    79
    The other way, conditions very nice!!
  5. #54
    30744
    SFV, Los Angeles
    980
    79
  6. #55
    Davey K's Avatar
    8602
    Aug 2016
    North East England U.K
    211
    your G.P.S unit seems to have a lot of lag! I have the speed niks app on my smartphone and can recommend that for a quicker reading.
    Following VR|46 and all things Moto GP.
  7. #56
    447
    That's amazing, Leo. I had my Grom up to 8,000 rpm in 4th (62 mph) one time on the freway and it creeped me out going so fast on such a tiny bike!
    TOCE Dual Exhaust
  8. #57
    I was doing about 78 on an on-ramp to the I5 and hit a large transition, death wobble started an I thought I had crapped my pants, worse I've ever experienced on a bike. I no longer use that on ramp.
  9. #58
    30744
    SFV, Los Angeles
    980
    79
    Quote Originally Posted by Djezspin View Post
    I did that same thing last year on an '86 Ninja 600R. I was on the 10 fwy one night heading west approaching the 57 North and had a tank slapper so severe at 110 mph that it bruised my knees. That bike is gone, good riddance. I left it at the dealer for the auction yard.
  10. #59
    30744
    SFV, Los Angeles
    980
    79
    I did a couple speed runs over this last hot Sunday out here in Los Angeles. My GPS showed a peak of 72.79 mph and my speedo flickered 77 mph as the engine hit the rev limiter. I've always needed a down slope to hit the limiter in 4th even with the 36T rear sprocket. I'm thinking a rear tire wearing was just enough to up the dial since I"d only seen 76 indicated at the limiter previously.
    For my setup, I can just subtract 4 mph from the gauge and know my real speed that I've dialed in over the last two months that I"ve had this bicycle GPS device.
    Going up and down the long steep hills along the 101 fwy from Calabasas to Canoga Park CA at full throttle pretty much the whole way for 15 to 20 miles, my stock engine Grom showed 50 to 77 mph indicated on the speedo again wide open most of the time. That means going up those unusually steep hills I may be going a sketchy, slow 45mph? All them cars slow down too while going up the hills so there is no 30 mph difference when in the far right lane.
    The Grom may be slow on the highways but it can still hang with the flow.
  11. #60
    5746
    San Francisco
    1142
    273
    Where can I buy a Unicorn Grom?
    Paultergeist and Leo310 like this.
    235 2 Valve
    Supercharged AMG C43
    BMW M3
    2017 GSXR 750
  1. Replies: 10
    Last Post: 04-07-2018, 01:44 AM
  2. Nothing fancy grom stunt bike build?
    By supermotoboy in forum Grom How-To's and Guides
    Last Post: 10-25-2016, 03:06 PM
  3. 60 mph
    By gromaniac in forum Grom Talk
    Last Post: 03-06-2016, 06:56 AM
  4. Replies: 7
    Last Post: 09-24-2015, 06:35 PM
  5. Mods Mods Mods YUMINASHI RACING
    By Vinson in forum Grom Performance
    Last Post: 09-01-2013, 07:30 PM
grom 0-60
honda grom 0-60
