Differences between the new Yuminashi ECU and Finbro’s ECU ?
This is a discussion on Differences between the new Yuminashi ECU and Finbro’s ECU ? within the Grom Performance forums, part of the Honda Grom Garage category; The non programmableYuminashi ECU is relatively new and not many have used it yet, but what are thedifferences between the new Yuminashi ECU and Finbro’s ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 45
Like Tree15Likes
Thread: Differences between the new Yuminashi ECU and Finbro’s ECU ?
    5761
    Everett, WA
    69
    The non programmableYuminashi ECU is relatively new and not many have used it yet, but what are thedifferences between the new Yuminashi ECU and Finbro’s ECU?
    According to the internet -
    Both are modified/reprogrammed Keihin ECUs and are “selflearning” using the stock narrow band O2 sensor.
    They both can be used with modified or big block motors byusing a larger fuel injector.
    Finbro ECU —
    Rev limiter set at 12,500 rpm
    Need to re pin the wiring harness
    No cold start circuit
    Yuminashi ECU —
    No rev limiter set
    No need to re pin (only for OG Grom)
    3,681
    pretty sure oyu listed the diffs as far as i could tell. both are keihin.
    7,738
    I know I tried the Finbro ECU way back when, I had to repin on my 2014 grom, this was when ECM was new to the grom BBK kit tuners and not much was known how to do a good tune and for me I tried it on both my 170-183-2v engine and I had nothing but bad luck, either running too rich or not holding idle at cold start.
    I bought two of the Yuminashi ECU because the price was right and I figured I could use it for future DIY testing. The finbro ECU is about $164 at Finbro North America and the Yuminashi is only $73.42
    The use of the Yuminashi also recommends that the throttle body size and F/I be changed or DIY until you get the performance you need.
    here is a link on the item for yuminashi and how to repin on SF grom or monkey bike
    YUMINASHI POWERSPORTS ECU (MSX/GROM & SF - Z125 MONKEY - WAVE125i) (38770-K26-901R)
    1000
    347
    I'm running a Yuminashi ECU right now... currently with a DingerBuilt extra long intake
    ...and a modified stock exhaust... just cat, no muffler.
    The low price was very attractive so I took a chance on one.
    I don't yet know if the Yuminashi lacks a cold start feature because it hasn't been cold enough to trigger it. I'm assuming it doesn't just like the Finbro. It's not a problem here because the weather is mild. Even in the cold with the stock ECU the engine would high idle for only a minute before dropping down. It's highly likely Yuminashi and Finbro are the same product. Mileage has been good with it... 139.0 mpg so far. It's pinned for the OG so four wires need to change sockets to work on a SF.
    Repinning is lots of fun! (lol)
    TOCE Dual Exhaust
    2,117
    Quote Originally Posted by tooter View Post
    oh mylanta. Id honestly love to see what that thing does to the torque curve. That thing is massive.
    1000
    347
    It's not magic but I'm sure it helps. I'm curious too, and when I can find the time, I'll put the TOCE exhaust back on it and get it dynoed.
    TOCE Dual Exhaust
    2,307
    fyi, cold start is triggered on oil temps, so if the motor is "cold" (ie hasnt been ridden in awhile) it will turn on it even with warmer ambient temps. Sounds like the yuminashi doesnt have this... which makes sense as none of the asian market groms have it.
    shush319 likes this.
    3,681
    ill check on mine if it triggers the cold start solenoid next time i bring it home from work.
    is Big Ol' Pile of Dem Bones
    shush319's Avatar
    22114
    Jul 2017
    Daytona Beach, FL
    120
    Finbro is a self learning (auto-tune) ECU originally for a CB150R, re-flashed to "work" on the MSX/Grom.
    Yuminashi is a MSX125 (Thailand) ECU re-programmed to achieve 13.1-13.2 AFR (confirmed by Yuminashi via Facebook Messenger) through the whole RPM range (auto-tunes), w/o a rev limiter. Also w/o "Cold Start" (also verified by FB messenger) because the MSX125 does not have/need cold start. And is Plug-n-Play on the OG, needs stock harness re-pinned for the SF. Also half the price of the Finbro ;-)
    1000
    347
    Quote Originally Posted by shush319 View Post
    You're just gonna set off the Quibbler again. (lol)
    Also w/o "Cold Start" (also verified by FB messenger) because the does MSX125 not have/need cold start. And is Plug-n-Play on the OG, needs stock harness re-pinned for the SF. Also half the price of the Finbro ;-)
    Thanks for the info, man.
    The Yuminashi ECU also doesn't have a reset function like the stock ECU because it doesn't need it.
    TOCE Dual Exhaust
  1. the new 'yuminashi' ecu and PCV/WB install/ initial test
    By m in sc in forum Grom Performance
    Last Post: 04-26-2019, 12:25 PM
  2. Replies: 19
    Last Post: 07-28-2016, 08:07 PM
  3. For Sale F/I, 2 PC-150, 2 yuminashi 10 hole, one yuminashi 14 hole
    By CiscoSanJose in forum Parts for Sale / Wanted
    Last Post: 05-26-2016, 03:45 PM
  4. Replies: 32
    Last Post: 04-06-2015, 12:31 PM
  5. Differences Thailand / USA / Europe version?
    By a_morti in forum Grom Talk
    Last Post: 01-21-2015, 03:14 PM
yuminashi ecu reset
