Differences between the new Yuminashi ECU and Finbro’s ECU ? - Page 4
This is a discussion on Differences between the new Yuminashi ECU and Finbro’s ECU ? within the Grom Performance forums, part of the Honda Grom Garage category; they are not the same. the yuminashi is a grom ecu, the finbro is a cbr150R...
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 45
Like Tree15Likes
Thread: Differences between the new Yuminashi ECU and Finbro’s ECU ?
  1. #31
    649
  2. #32
    7,834
    ^^^^^What he said, but it works^^^^^
    but you would be better off with the Yuminashi because it is cheaper than the Finbro
  3. #33
    3,715
    they are def not the same. and, for whatever reason, the yuminashi ones is OK with the PCV writing a functional map in the closed loop, whereas the finblow wont allow it (from what i have read). I dont know why. But it works.
    also, side note for potential PCV/Yuminashi users, the 'rev extend' limiter does work with the yuminashi (that has no limiter), actually adding a rev limiter to the system, which IMHO is a good thing, especially incase of a mis shift.
    Djezspin and farkas like this.
  5. #34
    30240
    Oct 2018
    FL
    20
    So, to update my previous post. My Finbro and my friend's Yuminashi are about the same performance wise. We are both able to hit 70mph easily and he has a much better cold start. Again, refer to my previous post for the mod list. Personally if you want to have a budget bolt on bike, I wouldn't be against this ECU. The plugs look identical as well
  6. #35
    7,834
    One of my grom friend in SF has used the Finbro ECM with PCV and was able to make it work and his engine was a 125 with a lot of other stuff he did to the engine such as cam etc. The Finbro or yuminashi are good choice but like I said the yuminashi is cheaper in cost $70 vers $125 for the Finbro.
  7. #36
    446
    Quote Originally Posted by c0rkscrew View Post
    Neither would I. For the price, I was willing to take the chance. And I believe that's the biggest difference. My Yuminashi has no cold starting issues. It cold starts and idles without touching the throttle. I can smell a hint of fuel in the exhaust on cold idle so the mixture is plenty rich enough to keep the engine from dying. I just changed 4 wires, plugged it in, and ran it.
    TOCE Dual Exhaust
  8. #37
    I'm currently tuning my new build and I'm running a 4 gear map in PCV. My ECU refuses to let my PCV control the rev limit in 1st gear and hiccups every once in a while in 2nd gear. No problems in 3rd. I ordered my Yuminashi on Thursday. If all I get from it is the fact there is no rev limit and my PCV can take care of the rest then I'm going to say that the $75 is more than worth it. If I can in fact start controlling the AFR's in the closed loop with the Yuminashi then even better. But the arguing between the stock ECU and PCV rev limit just has to stop. It's worse than arguing with the wife
  9. #38
    3,715
    ^ yup. you;ll be good. it will take a WHILE for a 4 gear map to tune, did on mine. the yuminashi ecu when 1st put in will cause the mids to be very rich, just be warned, its a pia. I actually added -5 to all the tables to get it to tune faster, it helped. .02
    Djezspin likes this.
  10. #39
    Thanks for the heads up, I'll be watching my AFR's closely. Can't wait for ECU to come in. It's going to be about a week before it ships because I ordered a few other items that are on backorder. I should've just placed 2 orders, lol.
  11. #40
    446
    Quote Originally Posted by Djezspin View Post
    Just heads up, dj...
    ...repinning the wires is tedious. DO NOT CUT any wires because some go into empty sockets on the connector. Instead pull out the wires from connector WITH the sockets attached. Also double check the socket numbering. If you use the Honda shop manual as your reference, remember the numbering diagram is of the ECM side with the male terminals, NOT the connector side with the female terminals. Check, double check, triple check you're moving the right wires to the right locations so you only need to do it once. If they're done right the ECU will work great.
    TOCE Dual Exhaust
  1. the new 'yuminashi' ecu and PCV/WB install/ initial test
    By m in sc in forum Grom Performance
    Last Post: 06-09-2019, 09:20 AM
  2. Replies: 19
    Last Post: 07-28-2016, 08:07 PM
  3. For Sale F/I, 2 PC-150, 2 yuminashi 10 hole, one yuminashi 14 hole
    By CiscoSanJose in forum Parts for Sale / Wanted
    Last Post: 05-26-2016, 03:45 PM
  4. Replies: 32
    Last Post: 04-06-2015, 12:31 PM
  5. Differences Thailand / USA / Europe version?
    By a_morti in forum Grom Talk
    Last Post: 01-21-2015, 03:14 PM
yuminashi ecu reset
