8 and 10 hole injector on 170 4V - Page 8
This is a discussion on 8 and 10 hole injector on 170 4V within the Grom Performance forums, part of the Honda Grom Garage category; Don't think it flows anymore than the 6 hole injector. I can tell already it idles lean even with air screw all the way closed. ...
Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 76 of 76
Like Tree21Likes
Thread: 8 and 10 hole injector on 170 4V
  1. #71
    is bbk woohoo!
    humilde_s13's Avatar
    1400
    Sep 2013
    Virginia
    13500
    636
    Takegawa 181cc
    Finbro head
    Koso 34mm
    Yoshimura cam
    Aracer rc mini plus 2
  2. #72
    sounds like the ecm is the issue here more than anything, or at least the setting on it.
  3. #73
    is bbk woohoo!
    1400
    Sep 2013
    Virginia
    13500
    636
    I'm done buying injectors. Buying the bazzaz to fine tune the finbro ecm.
    Takegawa 181cc
    Finbro head
    Koso 34mm
    Yoshimura cam
  5. #74
    2,370
    if you are running the 181 cc, you NEED the 10 hole (forza / cb1100) injector for sure.
  6. #75
    use stock ecm, sell the finbro one and get a powercommander w wb2.
  7. #76
    keit29's Avatar
    6117
    Aug 2015
    Columbus OH
    291
    I run a Finbro ECU (no stock o2 sensor) now along with my Dobeck AFR+ and a 10-hole forza injector on a 181 "max effort" 2 valve setup. The cold start enrichment always fought with the AFR+ with the stock ecu. I've been told the finbro ecu timing is 3 degrees less than stock across the board. Also, I now have a 12k rev limit. Looking forward to building a 4v motor soon and I plan to just bolt this setup up and it should work well there too.
    humilde_s13 likes this.
  1. Needed 6 hole injector
    By 321GromInk in forum Grom Builds
    Last Post: 06-20-2016, 05:47 PM
  2. Finbro 6 hole vs. Finbro 8 hole injector
    By keit29 in forum Grom Performance
    Last Post: 05-29-2016, 02:40 AM
  3. For Sale F/I, 2 PC-150, 2 yuminashi 10 hole, one yuminashi 14 hole
    By CiscoSanJose in forum Parts for Sale / Wanted
    Last Post: 05-26-2016, 04:45 PM
  4. Replies: 8
    Last Post: 09-18-2015, 05:58 AM
  5. What is this threaded hole?
    By timmysd88 in forum Grom Talk
    Last Post: 06-15-2015, 05:59 PM
16450-k56-n01
cbr 150r 8 holes injector
grom 4v injector size
hole injektor pcx
pcx150 fuel injector and fuel line
